Closed Thread
Old 04-08-2012, 04:28 PM   #626
JumboAMONGus
JumboAMONGus's Avatar
Re: What Did You Do With Your Truck Today ?
lowered my 71 chev c10 thiss weekend , tore an upper ball joint boot so need to run to napa for a new one , , and ordering some cpes epoxy wood sealent for my 56 chev bed wood stuff works awsome on my wood boat figured look good and last longer this damn inner lock ,,, gives me tons of timeto work on trucks ,, lol
JumboAMONGus is offline
Old 04-08-2012, 08:18 PM   #627
87Lowrider
Navy Radioman Veteran
87Lowrider's Avatar
Finally got back on the '57 Build (after 5 long years)...
87Lowrider is offline
Old 04-08-2012, 11:15 PM   #628
JumboAMONGus
what kinda of rear is that ?...
Old 04-08-2012, 11:17 PM   #629
JumboAMONGus
finally got the 5 /5 drop done on my 71 , and never again will i use 15inch wheels on a 3 inch drop spindles ,, nor will i do a drop ..lol thing sits so low i couldnt get jack out of it ,and the tires rub so new rims tires in a month ,[/IMG]
Old 04-09-2012, 09:53 AM   #630
87Lowrider
87Lowrider's Avatar
It's a '73 Jag XJ6. I bought it years ago. I also purchased the mounting kit for the '55-'59 series trucks from a company call Concours West. They had everything needed. I can't find them anymore. I think they went out of business.
This is the look I'm after:
Old 04-09-2012, 01:18 PM   #631
oldcouple
oldcouple's Avatar
here is a link to Concours West
http://www.hellotrade.com/concours-w...s/profile.html
Retired and too busy to work.
oldcouple is offline
Old 04-09-2012, 02:25 PM   #632
87Lowrider
87Lowrider's Avatar
Originally Posted by oldcouple View Post
Thanks for the link... They still some things I'd like to have. Gotta call 'em sometime.
Old 04-09-2012, 03:22 PM   #633
Russell Ashley
Russell Ashley's Avatar
I installed my Juliano's seatbelts. They look good and the color is actually darker blue than the pics make them look. They say to pop rivet the upper anchor to the cab but I threaded the two small holes instead and used chrome button head allen screws to hold it in.
I had to remove my jack from it's factory location in order to attach the driver side retractor so it will probably reside under the seat now.
In case anyone hasn't seen it, here's a video of installing seat belts in a TF.
http://www.bobshotrods.com/howto/3-p...chevy-pick-up/
I'm only 5' 10" tall but I run my seat all the way back. I couldn't mount the inner part of the belts like they say in the video because they weren't long enough to reach up between the seat back and cushion. I had to mount them on top of the ridge that holds the gas tank straps and even now you can see in the pic that they aren't overly long. Anyone else run into this?.
Russell Ashley is offline
Old 04-09-2012, 07:03 PM   #634
Mrcustom
Well I got it in waiting for radiator to finish it up
Mrcustom is offline
Old 04-09-2012, 07:52 PM   #635
Daze57
Daze57's Avatar
seat belts and seat look great !
Daze57 is offline
Old 04-09-2012, 07:52 PM   #636
Daze57
Daze57's Avatar
motor looks great also
Daze57 is offline
Old 04-09-2012, 08:01 PM   #637
lowdownstar
big guy
lowdownstar's Avatar
That is one sweet looking motor!
Ray
lowdownstar is offline
Old 04-10-2012, 11:27 AM   #638
mknittle
mknittle's Avatar
Lots of good work going on here!
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline
Old 04-11-2012, 08:43 PM   #639
OrrieG
OrrieG's Avatar
Nothing but we are cleared for a push now that the greenhouse is dried in and usable. Going to finish the steering wheel change, then start final body work on bumpers, door interior, grille and misc interior items for paint (matching the cab interior color). Then fuel door and fill pipe. Gas it and start the engine.
OrrieG is offline
Old 04-13-2012, 04:52 PM   #640
Dan in Pasadena
Dan in Pasadena's Avatar
Smart and a LOT better looking than pop rivet heads showing. Though I suppose you could dimple the pop rivet locations and then fill with weld or filler and smooth them over. I also wonder if you even NEED these rivets/bolts? Won't the 1/2" bolt hold the backing plate adequately all by itself?
Dan in Pasadena is offline
Old 04-13-2012, 06:26 PM   #641
55Cameo
55Cameo's Avatar
I drove my truck to my hobby unit to start on my rebuild with lots of upgrades!!! I'm very excited because its gonna get the long well deserved much needed love. I finally get to do things the right way.
Ill be making a build thread n post pics soon
55Cameo is offline
Old 04-13-2012, 07:37 PM   #642
Russell Ashley
You do need the rivets or screws. The anchor bolt that holds the belt has a shoulder about 1/2 inch long, which tightens against the bracket, not the cab wall. It would be kind of sloppy and rattle if you didn't have the rivets or screws.
Old 04-13-2012, 08:30 PM   #643
Speedbumpauto
Speedbumpauto's Avatar
Finished the bed inside this afternoon. Roll pan, fenders and put it on the frame next week. It's Miller time now!
Speedbumpauto is offline
Old 04-14-2012, 12:24 AM   #644
Dan in Pasadena
Oh, ok got it. Makes snese.
Old 04-14-2012, 01:13 AM   #645
55Cameo
55Cameo's Avatar
here's a couple pics
55Cameo is offline
Old 04-14-2012, 07:28 PM   #646
oldcouple
oldcouple's Avatar
Detail painted the inner door frame, and inside step, used the spray bedlinner stuff on the steps looks nice, now if I can just keep it clean. Wrinkle painted the upper part of the dash, lots of masking. Lower dash and ceiling and rear of cab to go.
Old 04-16-2012, 10:27 AM   #647
yossarian19
Actually it was Saturday but I got the truck out from under the cab-over camper, all the loose underhood parts secured in place with bailing wire, piled all the loose nuts, bolts, driveshafts etc into the cab, loaded the cylinder head (HEAVY!) into the bed & got it ready to tow back to Berkeley.
The truck lives in Grass Valley at the moment, but I'm finally just one trip with a trailer away from bringing it back to the shop in Berkeley. ~3 hours drive each way.
Oh, and I continued obsessing over which brake kits, which engine, which carpet & which gas tank I'm going to want.
yossarian19 is offline
Old 04-16-2012, 11:23 AM   #648
focusedontheprize
focusedontheprize's Avatar
Ordered my hardware for the suspension, battery box, and polyliner for my leaf springs. This weekend is going to be a wash, but the following weekend I will pick up the rear end out of the yard and hopefully have the front end suspension put back together.
focusedontheprize is offline
Old 04-20-2012, 07:02 PM   #649
51 okie
Active Member
Recently added the chrome wheel center caps. Today I threw an old bed in the back and took it to Salvation Army. Fun to drive that beast.
51 okie is offline
Old 04-20-2012, 08:48 PM   #650
rollenhard
rollenhard's Avatar
Hey 51 okie cool looking truck
rollenhard is offline
Closed Thread
