Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 10-14-2010, 11:59 PM   #26
warden
Re: WARNING! Read This if You Use a Welder
I know brew dude, and he attended sturgis that year with us. He was there only one day and then had to leave due to the illness. We thought we'd lost a good fellow builder...fortunately he was wise in getting to hospital in time....
warden is offline   Reply With Quote
Old 10-19-2010, 08:10 PM   #27
R.L.
R.L.'s Avatar
R.L. is offline   Reply With Quote
Old 02-16-2012, 05:32 AM   #28
TheCustomFactory
TheCustomFactory's Avatar
They used to use phosgene in chemical warfare. Nasty stuff.
TheCustomFactory is offline   Reply With Quote
Old 04-03-2012, 06:53 PM   #29
Eddie H.
Eddie H.'s Avatar
Phosgene gas was used as a chemical weapon in WW1. It is also created when refrigerant is exposed to heat or open flame. Back in the old days we used to just vent the refrigerant into the air when working on AC systems. ( Before recovery systems were mandated by law) One guy got deathly sick just from smoking a cigarette in the area where he was venting freon into the air.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 04-03-2012, 09:33 PM   #30
mbgmike
Yes it was. I have been in the mfg of it. We made it at Dow and GE. It is used in making plastics. I personally have worn full SCBA gear in rooms filled with 100% phosgene and 0 oxygen. you get used to it after the first time.
mbgmike is offline   Reply With Quote
Old 04-03-2012, 11:09 PM   #31
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Thanks guys for bringing this old thread to the top.
I'll see if we can get it to migrate elsewhere.
Must admit that I have tended to think brake cleaner to
be safer than carb cleaner. Not. Thanks for the heads up!
ETsC10 is offline   Reply With Quote
Old 04-09-2012, 03:15 PM   #32
lyrikz
PITbut
lyrikz's Avatar
Wow, i stumbled upon this when i was searching ETsC10 posts looking for when the next swap meet was.
Yesterday i was working on my new project.
Fatty Mc Chub Chub
Its my wifes car. Anyways, i made a patch panel for it, and before i welded i sprayed it off with brake clean and then started welding. When i weld, i sometimes hold my breath because i dont like the smell. well, i take a big breath and start welding and hit a spot of brake clean. I continue on with no issues. Later that night my left hand wont stop twitching. Sunday it was better.
I could of EASILY ended up like that dude if i didnt hold my breath like an idiot when i weld.... I had NO idea this stuff was so nasty.
pass this on.
New project. 1971 Twin Turbo blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=676047
My new YOUTUBE channel.. Videos of my truck and a current walk around.
Lyrikz74 Youtube channel DONE! SOLD!
My 1971 stepside build thread
My Build Thread UPDATED 6/11. DONE
and sold.
lyrikz is offline   Reply With Quote
Old 04-09-2012, 04:11 PM   #33
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Holy Schnikies!
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 04-12-2012, 07:05 AM   #34
C-10cutty
C-10cutty's Avatar
A real eye opener.
I never use brake cleaner myself, just carb, but I've a good friend I need to alert to the hazard.
C-10cutty is offline   Reply With Quote
Old 04-12-2012, 08:30 AM   #35
bigsnookmaster
bigsnookmaster's Avatar
Fatty Mc Chub Chub
pass this on.
I tend to hold my breath too! I always use laquer thinner, or mineral spirits to clean before I weld new steel. Good info here!
bigsnookmaster is offline   Reply With Quote
Old 04-12-2012, 08:40 AM   #36
jjzepplin
jjzepplin's Avatar
This should pm'd to all members!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 11-13-2015, 11:00 AM   #37
vtblazer
vtblazer's Avatar
Bump cause this **** is good info to know!
vtblazer is offline   Reply With Quote
Old 11-13-2015, 10:32 PM   #38
ERASER5
ERASER5's Avatar
Any CFC type products will do this. Sucking on a cigarette while working on your AC system is a BIG NO NO. You think inhaling tar and nicotine is bad, throw in a little phosgene gas for more kick.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 01-23-2017, 11:35 AM   #39
Hewfil1
Hewfil1's Avatar
I always knew CFC Brakeleen was some serious stuff, but this, Dang!
Knew a guy who rebuilt transmissions and used the Brakeleen on everything. Can't even build anymore because he so much as picks up a wrench and he'll bust his hand. Doctors told him the stuff ate holes in his bones.
Hewfil1 is offline   Reply With Quote
