Old 03-15-2012, 07:50 PM   #201
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 72 Cheyenne Super First Project
Bump for you so some one can get you some pics!
Ryan
1969 Chevy milk truck
Old 03-15-2012, 08:55 PM   #202
gcburdic
Restoration Virgin!
gcburdic's Avatar
Originally Posted by Graham57a View Post
does anyone have pictures of how the stock shift linkage for an automatic goes together?
here ya go buddy....
http://67-72chevytrucks.com/vboard/s...d.php?t=368713
What tranny you gonna run??...I posted a thread awhile back on the difference between TH350 vs TH400 shift linkage....didn't really get an answer, so not sure if it makes a difference
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 03-16-2012, 09:25 PM   #203
Graham57a
Graham57a's Avatar
Thanks Geoff. I got the part where it connects to the trans but the part where the arm connects to the steering shaft confuses me. It looks like the end of the rod is broken off and Idk if it came like that or if mine is broken.
Graham57a is offline   Reply With Quote
Old 04-09-2012, 11:23 AM   #204
Graham57a
Graham57a's Avatar
Tiny bit of progress, got some parts from Summit and threw them on the truck. Also repainted the sun visors and headliner.
Old 04-09-2012, 11:26 AM   #205
Graham57a
Graham57a's Avatar
Also got a wire gutter and a new gas pedal from the truck shop
Old 04-09-2012, 11:31 AM   #206
Graham57a
Graham57a's Avatar
Here are the pictures of the dent we fixed in the tailgate. I know its not perfect but it's a ton better
Old 04-09-2012, 11:35 AM   #207
Graham57a
Graham57a's Avatar
Last few for the picture junkies. Also the last picture is the steering column end of my shift linkage. Is this right? It looks broken to me. ADVICE NEEDED
Old 04-09-2012, 02:17 PM   #208
JD'S 69
JD'S 69's Avatar
Nice work
JD'S 69 is offline   Reply With Quote
Old 04-09-2012, 04:15 PM   #209
67cheby
67cheby
67cheby's Avatar
very clean ! nice work
67cheby is offline   Reply With Quote
Old 04-09-2012, 06:42 PM   #210
Graham57a
Graham57a's Avatar
Thanks guys. Made a little more progress today, nothing to impressive.
Old 04-09-2012, 06:46 PM   #211
Graham57a
Graham57a's Avatar
Couple more
Old 04-09-2012, 07:05 PM   #212
Dieselwrencher
Andrew, did you figure your shift rod issue out? I know some of the ones I've had looked odd where they were cut at the factory. Almost looks like they forced a shear to cut them fast or some thing.
Ryan
Old 04-09-2012, 10:54 PM   #213
Graham57a
Graham57a's Avatar
Still haven't figured it out.
Old 04-10-2012, 12:39 AM   #214
longbed67
longbed67's Avatar
Looking real clean! Are you going to sleeve the rest of your coolant/ heater hoses to match the vacuum and upper radiator hose?
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline   Reply With Quote
Old 04-10-2012, 09:02 AM   #215
gcburdic
Restoration Virgin!
gcburdic's Avatar
Coming right along there Andrew....I can get ya a picture of my shift rod tonight buddy....might want to put some protection around that fuel line coming out of the filter to the pump just incase it rubs the frame...also, did ya think about painting that fuel line up to the carb to hide it??
Geoff with a G
Old 04-10-2012, 09:55 AM   #216
Graham57a
Graham57a's Avatar
I don't think so. That hose I used for the vacuum line and upper rad hose is really expensive. My dad had those pieces laying around his shop so he let me use them. The heater hose is gonna stay the original rubber for now.
Old 04-10-2012, 10:01 AM   #217
Graham57a
Graham57a's Avatar
Thanks Geoff, I would really appreciate those pictures if you can get me some. I already know how the trans end goes together, I just can't figure out the end that connects to the steering column. The fuel line before the filter is lacking a clamp about two feet down the frame rail because I didn't have a 90 drill that would fit in there. So once I get that clip on it should pull that line closer to the frame rail and it won't move. Also I might redo that fuel line to the carb with stainless. I don't really like how this one turned out so I'll probably be doing another one.
Thanks for the compliments guys, I landed a really good job with a race team this summer so I'm hoping to have it finished by my sister's wedding in August. I finish exams May 10th so I'll be home for the summer after that. Stay tuned
Old 04-10-2012, 07:47 PM   #218
Dieselwrencher
Good luck with youe exams Andrew! And congrats on the new job for the summer!
Ryan
Old 04-11-2012, 01:13 AM   #219
Graham57a
Graham57a's Avatar
Thanks Ryan, I'm really looking forward to the job. I'm back at school now, time to be studious and keep working on my truck in my head
Old 04-11-2012, 04:24 PM   #220
longbed67
longbed67's Avatar
Props to ya for being able to go to school and leave your project at home! I cant wait to hit the shop for a little bit after class each day during the week!
Adam
(608) 214-8706
Old 04-11-2012, 05:10 PM   #221
Graham57a
Graham57a's Avatar
I wish I had that luxury. I have to wait for holidays, haha. I'm going to be stuck in the garage this summer tho
Old 04-13-2012, 08:31 PM   #222
Graham57a
Graham57a's Avatar
Geoff, did you get around to taking those pictures for me?
Old 04-13-2012, 09:30 PM   #223
mcbassin
Still Learning
mcbassin's Avatar
Nice progress! Can't wait till I'm that far along. Keep it up.
Old 04-13-2012, 09:34 PM   #224
Graham57a
Graham57a's Avatar
Thanks man, it's been almost 3 years. Seams like its been 20. Should be done by August hopefully
Old 04-15-2012, 12:04 PM   #225
Graham57a
Graham57a's Avatar
Does anyone know how many pounds a stock height spring is? Front and rear if possible?
