Old 04-09-2012, 10:49 PM   #2
67c10rustbuket
67c10rustbuket's Avatar
Re: 67-72 on later chassis
the 73-87 wont work without a lot of work because the frame rails are raised at the back of the cab under the seat where the 67-72 is straight. Well it will work if you try hard enough but most only do it on 4wd models because you have to do a body lift to make it fit the frame. There is one guy on (that I know of) here using a 99+ NBS silverado chassis. That looks like a much better choice with the LS drivetrain and all. Maybe an 88-98 chassis would do the trick they are straight under the cab. Good luck
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
