Old 04-11-2012, 03:23 PM   #1
gag1025
Rebuild Question
Since I am doing an off the frame restoration, I would like to know if there is anything I can put between the metal parts to reduce squeaking. Right now it is bolted down metal on metal and it squeeks. Rubber would do this but would deteriorate over a short period of time and the problem would be worse.
gag1025 is offline   Reply With Quote
Old 04-11-2012, 03:26 PM   #2
izonme13
izonme13's Avatar
Re: Rebuild Question
What metal parts are you refering to? That would help us to answer your question.
izonme13 is offline   Reply With Quote
Old 04-11-2012, 03:47 PM   #3
gag1025
All metal parts where they bolt up to other metal parts. Example: The running boards bolted to the brackets.
Old 04-11-2012, 04:40 PM   #4
1953chevyroc
1953chevyroc's Avatar
http://www.chevsofthe40s.com/detail/...NT_FENDER.html
this is for the fenders but I'm sure you could find something for the running boards.
1953chevyroc is offline   Reply With Quote
Old 04-11-2012, 05:38 PM   #5
gag1025
Thanks. Exactly what I am looking for.
