Quest for 11.50
Want to get my 86 shortie to 11.5 in the 1/4 I'm Planning on an overdrive 200r4 and some 373 gears with a locker and a 3000 stall converter with lockup and m&h race master 275 16s drag radials. My engine is putting out about 410 hp right now. I have a 5-7 drop on suspension and a race weight fiberglass cowl hood on the way.
What do you guys think it will take to pull up to 11.5? Haven't got any timed runs yet till the new trans is back in Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
mini truck racer
Re: Quest for 11.50
What does it run now ? Post the last time slip for us .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
Re: Quest for 11.50
Runs 13.65 with 295/50/16 bf Goodrich and a 308 open diff with th350 no stall just a shift kit. And had a 3-4 drop.
Posted via Mobile Device Forgot this was with no tailgate or hood
MOTORHEAD!
Re: Quest for 11.50
I would guess that your modifications will put you in the 12.8 range.
82 GMC High Sierra VortecPro 496 12 Bolt, 3.42's AFR 265 Holley 850 Performer RPM Air Gap Hooker 2455's TCI Turbo 400 Super Street Fighter TRRC 12 Bolt Eaton Posi Mark Williams Axles Cal-Tracs Hoosier 30x10.5 Radial Slick Full weight long box pickup Current best- 11.33@117mph |
Re: Quest for 11.50
So adding gears stall and less weight Get me halfway so then I guess more hp is in order? If I add about 90hp to my setup and lose wight with aluminum components( heads water pump and mini starter) how much closer would you say?
Re: Quest for 11.50
I'd say add Cal Trac Bars and 100 to 150 shot of nitrous. I would run Hoosier or Mickey Thompson Drag radials.
Good Luck!
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
Re: Quest for 11.50
At 3,525lbs (me in the truck) and 449rwhp (unlocked converter 410rwhp) I went 11.45 with the following drivetrain. 4L80E, 4,500rpm converter, 4.56 gear, 315/60/15 mt et drag radial. It probably would have went a little faster with a 26" or 28" tall tire as I was geared more for the bottle.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
MOTORHEAD!
Re: Quest for 11.50
To be clear, is your engine putting out 410hp, or is that rwhp?
Re: Quest for 11.50
On a chassis dyno with the converter locked it made 449rwhp. With the converter unlocked it made 410rwhp. I am not sure if a 200r4 has a locking converter. That is why I posted both numbers so it could be compared apples to apples.
#10 | |
Re: Quest for 11.50
And yes the 2004r is a lockup trans too. Same as the 700r4 just without the silly first gear ratio. I will absolutely not run my engine on a bottle. Posted via Mobile Device
![]() Join Date: Jan 2011
Re: Quest for 11.50
If the engine in your sig is the engine you're running, you can gain quite a bit by ditching that Thumper camshaft, and you dang sure ain't making no power at 8 grand with that setup, you're lucky it's still in one piece.
mini truck racer
Re: Quest for 11.50
A gear and posi is where i would start along with a set of tires . As stated above try shifting it sooner . If you feel it pull again when you shifted you shifted to late .
#13 | |
Re: Quest for 11.50
As for the 8k rpm. I built the valve train to take the abuse. An was very meticulous about my rotating assembly. Needless to say the cam doesn't support past 5800 rpm an I have a 6100rpm rev limit. Posted via Mobile Device
Re: Quest for 11.50
#15 |
Re: Quest for 11.50
Oh thought I had that in the original post. Haha forgot to add that.
