Old 04-12-2012, 11:35 AM   #1
LoudLowNslow
Dash indicators? Burnt/melted?
Hey guys, not sure what these are so I will include pics. Truck is a 66 gmc.
Left side, toggle switch on bottom, I think is for the blinkers? What did the stock one look like?
Right side, here you can better see the red colored things that appear to have been melted? What are these? Are replacements available?
1966 GMC stepdside shortbed- needs some love
LoudLowNslow is offline   Reply With Quote
Old 04-12-2012, 11:42 AM   #2
1963c-10
1963c-10's Avatar
Re: Dash indicators? Burnt/melted?
Turn signals are normally mounted on the steering column. You should see a slot for the lever just behind the wheel on the left side. ive never seen a toggle switch used for turn signals, as they normally are in the on or off position and turn signals would require two ons and an off. The red lenses you should be able to get used off someone here, I dont know of anybody repop'n them.
1964 Short bed trailer
Old 04-12-2012, 11:44 AM   #3
mtruckr
mtruckr's Avatar
Hello Loud-
My 66 Suburban has a regular turn signal stalk to the left of the steering wheel...
My dash bulb covers are also 'burned out'... I forget what someone else said, but top left is left turn signal, top right is right turn signal. One of the lower ones is the generator light. Not sure of the other- I'll check old posts.
Good Luck!
mtruckr is offline   Reply With Quote
Old 04-12-2012, 12:04 PM   #4
CRGRS 66
CRGRS 66's Avatar
the "lights, wiper, choke" labels are... quaint I will say! Sorry, I am new to the sport, and am learning the ropes on my 66 chev, good luck with the GMC, love to watch your progress
CRGRS 66 is offline   Reply With Quote
Old 04-12-2012, 12:45 PM   #5
mtruckr
mtruckr's Avatar
Loud-
This was a reply to my question a while back:
Dash lights on single dash models are as follows: Generator upper left (Lights
up when ignition is turned on, goes out when engine runs and generator
charges.), Hi Beam lower left (Goes on when headlight high beam is selected with
foot dimmer switch.) Low Oil upper right (Lights up when ignition is turned on,
goes out when engine starts. Buzzer sounds on some models. If tell-tale lights
up when truck is operating, investigate!) Turn Signal lower right (Flashes on
and off to show that directional signals are working.)
Old 04-12-2012, 01:41 PM   #6
Andyboy
Andyboy's Avatar
Originally Posted by mtruckr View Post
Loud-
Thanks two of mine are burnt out also. nice to know.
Andyboy is offline   Reply With Quote
Old 04-12-2012, 01:50 PM   #7
Greshampiglet
Look What I Have, Intrested
GreshamP1GLET
Greshampiglet is offline   Reply With Quote
Old 04-12-2012, 01:59 PM   #8
LoudLowNslow
How much for the indicators?
Thanks for all the replies guys, very helpful! I can't wait to get this thing running!
Old 04-12-2012, 02:11 PM   #9
Greshampiglet
Make me an offer for the whole thing
GreshamP1GLET
Old 04-12-2012, 02:13 PM   #10
Greshampiglet
Better picture
GreshamP1GLET
Old 04-12-2012, 02:15 PM   #11
Greshampiglet
Another picture
GreshamP1GLET
Old 04-12-2012, 02:44 PM   #12
A.T. RockDriller
A.T. RockDriller's Avatar
mtruckr is correct....
Chev and GMC differ in the idiot light/turn indicator department.
The lower right green lamp indicates turn sig...blinks the same way wether you're using left or right.
I guess the GMC engineering department figured we were sharp enough to tell which way we were turning..
Les Hunter
'59 3803 someday to be 3853
'63 GMC K1000...351E, TH400 Daily
'66 GMC 4000...351C, 5&2
A.T. RockDriller is offline   Reply With Quote
Old 04-12-2012, 02:52 PM   #13
A.T. RockDriller
BTW, Loud...
The problems that can cause melting of those lenses are ....
#1 Wrong Bulbs...(too many amps)
#2 Voltage Regulator Failure (usually, more than about 13 volts is too much. Often that will also start burning out the smaller dash bulbs.
Les Hunter
