Old 02-18-2012, 01:26 AM   #1
Kim57
Kim57's Avatar
Wiring Harness
Who are you guys using for wiring harnesses?
Right now I'm looking at these two companies.
Has anyone had experience with them?
My engine will have its own harness so I'm not sure how many circuits I will need for the rest of the truck. I would rather have more and nmot need them than the other way around.
http://stores.ez2wire.com/-strse-Kwi...Categories.bok
I've heard good things about Rebel Wire. They also make a kit that will put the fuse panel behind my seat.
http://rebelwire.com/
Thanks for any input.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 02-18-2012, 01:59 AM   #2
OrrieG
OrrieG's Avatar
Re: Wiring Harness
http://67-72chevytrucks.com/vboard/s...d.php?t=508146
from a couple of weeks ago
Old 02-18-2012, 05:28 AM   #3
GeorgeVale
Re: Wiring Harness
hi Kim I bought a ezwire harness not fully fitted yet but pleased with quality for the money. Have heard good things about the rebel kits but my local rodshop in the uk now sells the ez instead, probably as were all cheapskates here in the uk. Hope the new engine is working out looking forward to seeing a update on your build thread I really wanted a big block too but some things are not meant to be for time being at least. George
GeorgeVale is offline   Reply With Quote
Old 02-18-2012, 09:08 AM   #4
Larry Lindley
Re: Wiring Harness
American Auto Wire 21 GM color code
Larry Lindley is offline   Reply With Quote
Old 02-18-2012, 09:28 AM   #5
youngrodder
youngrodder's Avatar
Re: Wiring Harness
I used a American Autowire Highway 22. Very nice kit. They also offer add on acceseries for an afortable cost.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 02-18-2012, 11:37 AM   #6
Kim57
Kim57's Avatar
Re: Wiring Harness
Thanks for all the input guys, I appreciate it.
OrrieG
I read that thread also and was just trying to get as much info as possible.
Kim
Originally Posted by OrrieG View Post
My build thread
Old 02-18-2012, 01:13 PM   #7
blitz'd
vintage car junkie
blitz'd's Avatar
Re: Wiring Harness
Kim
Ive used both of these, both great kits with good instructions.
1950 chevy truck, s10 swap, bagged, v8, 18s
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=392761
blitz'd is offline   Reply With Quote
Old 02-18-2012, 01:29 PM   #8
Maximus
Maximus's Avatar
Re: Wiring Harness
I used the EZ Wiring harness, 21 circuit. strait from EZ in an ebay auction, and it was less than $200 shipped. great quality, vague simple instructions but I emailed them years later and they were quick to help. (and they are still around so that was a great sign!) wires labeled every foot or so, great simple kit. Factory GM Steering column turn signal/ignition wiring.
they also have a list of things to check out for while installing...
I recommend.
here is a different auction, but same kit
21 Circuit EZ Wiring Harness on eBay
Maximus is offline   Reply With Quote
Old 04-04-2012, 04:05 PM   #9
Kim57
Kim57's Avatar
Re: Wiring Harness
Just thought I would post what I ended up getting.
AAW Highway series 22.
Kim
My build thread
Old 04-04-2012, 05:21 PM   #10
_Ogre
_Ogre's Avatar
Re: Wiring Harness
now that clean area under your dash will fill up
make lots of notes when you do something not on the instruction.
drawings of relays with wire numbers and color help when you get down the road.
also any switches you add make a note.
i've had to refer back to my drawings a couple of times, save time and your sanity.
when i did the 11 power tour i took just a handful of tools,
plus my multimeter and all my electrical dwgs just in case
under my dash is pretty clean, but in the console where all the relays went is a cluster f**k
shop air compressor timer
Old 04-04-2012, 05:24 PM   #11
Kim57
Kim57's Avatar
Re: Wiring Harness
I'm going to try and get it behind the seat. If that doesn't work then it will be in the console.
Kim
My build thread
Old 04-05-2012, 01:29 AM   #12
55Cameo
55Cameo's Avatar
Re: Wiring Harness
I know you already bought yours, put i am using the Painless wiring 21 circuit kit. Great quality and I knew VERY LITTLE about wiring when I installed it years back and cam out great. Had good instructions and all the connectors and terminals and wire ties and clamps.
Every wire is labeled along the wire and I'm ready for all future creature comforts for a/c to power windows/locks to cruise when i get them. Had enough length wire to run and hide every where
Good luck with yours. Looking forward to how it comes out. I'm looking for a new one for my dads 71 Chevy p/u and seeing what others been using/like.
55Cameo is offline   Reply With Quote
Old 04-05-2012, 08:56 AM   #13
Kim57
Kim57's Avatar
Re: Wiring Harness
I looked at Painless also but found them to be a bit pricey.
I found this one for $398.00 and it has everything I need plus some.
The wires are all printed with the circuits and it has extra conectors. I won't know how good the instructions are until I start on it though.
Kim
My build thread
Old 04-05-2012, 12:23 PM   #14
jimig1
jimig1's Avatar
Re: Wiring Harness
I bought a painless kit shortly after I bought my truck. Hopefully I will be installing it soon. I bought it from Yogis and they were having a sale on it plus Painless was offering a $100 rebate at the time. If I remember right I ended up paying a little over $200 for it.
55 2nd series Chevy Pickup
2019 Chevy Equinox(Daily driver)
2011 Chevy Malibu (Wife's car)
MSRA Member
I went to a bookstore and asked the saleswoman, "Where's the self-help section?" She said if she told me, it would defeat the purpose.
-George Carlin
jimig1 is offline   Reply With Quote
Old 04-06-2012, 12:18 AM   #15
55Cameo
55Cameo's Avatar
Re: Wiring Harness
Kim
Yes the price is the down side to the kit, but at the time I bought mine, which was several years ago, I didn't have as many options as we do now. I am def happy with my kit and would highly rec it.
But like you, I am also looking for a more inexpensive harness from our current vendors for my dad's truck
Old 04-06-2012, 12:52 AM   #16
Daze57
Daze57's Avatar
Re: Wiring Harness
kim
i am sure w/ your ingenuity it will turn out just fine - all you work is top notch sir !
Daze57 is offline   Reply With Quote
Old 04-06-2012, 12:54 AM   #17
Daze57
Daze57's Avatar
Re: Wiring Harness
also - i am useing a AAW kit 21 circuit - to me everything is layed out v v well and info is in COLOR !!!!!!!!!!
Good luck and i think you will like your harness
Old 04-06-2012, 03:03 AM   #18
55dude
55dude's Avatar
Re: Wiring Harness
http://www.ebay.com/itm/UNIVERSAL-WI...sories&vxp=mtr American made and seems to have a great rep.
55dude is offline   Reply With Quote
Old 04-06-2012, 01:58 PM   #19
Rusty Hooker
Re: Wiring Harness
I went the simple route and used a 1978 Chevy pickup harness that was in one of my parts bins. Tons of circuits, everything was the right length and easy to install. I am a big recycler of parts and hate spending money to make myself more work..
Rusty Hooker is offline   Reply With Quote
Old 04-13-2012, 04:46 AM   #20
55dude
55dude's Avatar
Re: Wiring Harness
been using them for years the 73-87 chevy trucks. nice thing is doesn't matter if it's 1/2,3/4 ton or bigger since wiring is wiring.
