How rusty, is too rusty?
Just wondering if I'd be better off finding a better cab, or repairing this one?
Above windshield on both sides ![]() Pass. ![]() Drivers ![]() Pass. Cab corner ![]() Drivers front cab mount ![]() Same ![]() I think my biggest concern is above the windshield, if you guys need more pics I can go outside and take some. Thanks! Posted via Mobile Device
1966 GMC stepdside shortbed- needs some love |
Re: How rusty, is too rusty?
Guess it depends on where you are.
Out West, they'd throw that away. In your neck of the wood that's probably considered "relatively rust free"... .LOL
____________________________ |
New cab in my opinion
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Zero welding skills, I have a buddy that can though. I was thinking cab replacement also, but I'd have to go down south to get one. Don't know if I could ever find a clean 66 gmc cab seems like most are Chevys
#6 | |
1961 crewcab
rust is just like an iceberg.... what you see is only the tip, these all rust from the inside out, so if you have a pinhole and you cut 3 inches around it on all sides, and flip the piece over, your actual damaged/rusted metal could be the size of a quarter- this is just for a visibile pinhole... now imagine what the rest looks like...
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
My dash is in pretty good shape actually, didn't know that the dash would be the only difference!
Hard to find old trucks for at least for parts here in Louisiana. I have some ruff areas on the cab, but I'll just do what is takes to repair it.
1966 Chevy C10 Stepside 355ci sbc with 3speed OD 2021 GMC Sierra 1500 AT4 6.2 1980 Chevy Camaro z28 383ci 1990 Chevy Suburban 350 tbi 2x4 (sold) 1984 Chevy C10 sliverado short fleet 1997 Chevy C1500 short fleet |
Check my build thread, mine was worse yet... I had no skills at all and it was my first time but it turned out pretty good. It can be done with some time and patients. Give it a try before you throw in the towel on it and find another.....
My build thread: 1966 stepside http://67-72chevytrucks.com/vboard/s...d.php?t=486223 1965 GMC fleet http://67-72chevytrucks.com/vboard/s...d.php?t=651726 |
I say fix it, if you have the capabilities. They're not making them anymore, and they're getting harder and harder to find. In 10-20 more years they'll all be that much rustier, and you'll kick yourself for not fixing what you had back then. If you need some inspiration, look into what the early VW bus guys are digging out and restoring.
I think the one in the link below is one of the worst I've seen resurrected. http://www.thesamba.com/vw/forum/viewtopic.php?t=471779
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
Getting skills you don't have is part of re-building cars/trucks. I use to be afraid of painting ...thinking I could do a good enough job, when a buddy showd me how! Started just doing just primer, then inter fenders and frames, then door jams, and then whole vehicals. Painting is pretty easy actually ...prep it the key! ...MIG welding is next for me! Good Luck!
Mine looked about like that, and I was going to fix it. I pulled out the windshield and under the gasket the inner and outer roof panel were rusted through, that changed my mind.
There is a CL ad in my area of a guy with a 1963 GMC cab...Seems overpriced to me, but figured I would pass it along http://milwaukee.craigslist.org/pts/2928643128.html |
| Bookmarks |
