Still working on the COE
73-87 chassis questions....
Gentlemen! curious, im building a 48 GMC COE, and using a 76 chev 3/4 t chassis, has anyone had the experience of putting 1 ton duals on a 3/4 t?, it looks like it will fit with the drums fine but I question if it will have problems with rubbing against the frame? Wanting to use the 3/4 t because it looks like the rr would actually be a little narrower for fitting inside the older stepside box then a regular 1 t axel. Hope to hear some good answers! Thanks again!
Thanks again!
yeller
I am almost positive the rear end will fit without rubbing since I have seen 3/4 ton Suburbans with dually rears under them.
The COE looks cool...have any front shots you would like to share? -Jeff |
I'd love to see some front pics of that too! Looks good!
Kent Ballan ANY MAN CAN BUILD A TRUCK, BUT IT TAKES A REAL MAN TO CUT ONE UP! ![]() ![]() ![]() |
need to get more recent ones but heres a few
another
other parts i had, mix match ya know
hoping the ultimate turnout to be similar to this truck! cept this one is a chev
I think you'll be fine with the tire to frame clearance, but spring pertches and shock mounts on the axle will probably have to be cut off and rewelded on. For some dumb reason chevy moved the springs inward on 1 tons (probably for tire clearance) and the shocks go different directions.
'75 Chevy 3/4 4x4, 6" suspension lift, 3" body lift, 3" lifted gas tanks, '83 cab, '88 clip, 35" cooper tires, American Racing Baja rims, 350, 700r4, 208. |
