Old 04-16-2012, 12:54 PM   #1
cfan10
cfan10's Avatar
Cool Trip from houston to dallas, one way...what to check replace
Steering wheel is shaking at high speeds, but I didn't want to replace bushings, ball joints, tie rod ends and sleeves. Until I moved to dallas.
But I am doing an oil change, tune up, changing belts, tires, coolent, hoses, p/s pump, fan clutch, thermostat, oil pan gasket, waterpump gaskets, thermostat gasket, exhaust manifold gaskets. New interstate battery. Possily waterpump.
Is there anything I'm missing here. Transmission also needs front seals, so it has a slight leak, thinking I'll just top it off for the drive. But it will be taken care of in dallas.
Ujoint replaced, trans gasket, filter.
cfan10 is offline   Reply With Quote
Old 04-16-2012, 01:09 PM   #2
gramps
Re: Trip from houston to dallas, one way...what to check replace
Leaking front Trans seal = broke down. Done it twice I won't let another bad front seal claim another of my transmissions.
gramps is offline   Reply With Quote
Old 04-16-2012, 04:40 PM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
figure out your route,post it, members might be able to help if bigger stuff comes up
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 04-16-2012, 06:27 PM   #4
HTX86chevy
HTX86chevy's Avatar
That is an awesome idea. That is what makes this forum the best out there. everyone is willing to help at a moments notice.
HTX86chevy is offline   Reply With Quote
Old 04-17-2012, 12:37 AM   #5
grayharville
^^who I am^^ what I say>
grayharville's Avatar
Replace water pump and flush the radiator good. check all the tires, check the rear end fluid, repack front wheel bearings, spare tire, basic tool kit, extra fluids, snacks, beer, etc.
70 chevy LWB 350/TH350 Barn find (AKA the 70)
http://www.67-72chevytrucks.com/vboa...d.php?t=406364
East Tx Squares
grayharville is offline   Reply With Quote
Old 04-17-2012, 01:10 AM   #6
wyattglock
wyattglock's Avatar
Not sure if you are replacing or just checking air in the tires, but if you aren't replacing them or they are not new, get them balanced. Could help reduce the shaking a little.
wyattglock is offline   Reply With Quote
Old 04-17-2012, 11:06 AM   #7
xrcr
I'd check my speed on the trip. Loose front ends concern me. Take it easy.
xrcr is offline   Reply With Quote
Old 04-17-2012, 08:20 PM   #8
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
I'm in Austin.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 04-17-2012, 08:33 PM   #9
Goldfinger
Goldfinger's Avatar
as long as it's been properly maintain she will make it. DON'T FORGET YOUR BRAKES! I forgot to check them on a 1400mile trip ended up shattering the shoes and creating much more of a problem. other than that a maintained truck will do well
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
