Old 04-17-2012, 10:31 PM   #1
dme922
dme922's Avatar
72 chevy k10 5.3 engine swap
Im doing a complete restoration on my 72 chevy k10 and i have decided to give it a modern touch in the engine compartment while still having the classic look. I am needing some advice on the best transmission and transfer case combinations with the 5.3L swap. Also some info on the engine crossmember and any other modifications. If this helps i have a 4 inch rough country lift that im going to start installing tomorrow. Any info will be greatly appreciated.
dme922 is offline   Reply With Quote
Old 04-17-2012, 11:11 PM   #2
Crash_OK
Crash_OK's Avatar
Re: 72 chevy k10 5.3 engine swap
I used a 4l60e mated to the NP205 TC. I ordered the parts needed to mate th two together from advanced adapters.
Good luck with your build.
Mark
Crash's 69 4x4 SWB
Crash's Roof over Lake Home
Crash's 1988 Land Cruiser Build
Crash_OK is offline   Reply With Quote
Old 04-17-2012, 11:21 PM   #3
dme922
dme922's Avatar
I was looking at using a 700r4 out of a 93 chevy 1500 but i am not sure that it will bolt up to a 5.3????
Old 04-18-2012, 02:17 PM   #4
6772owner
Gearhead
6772owner's Avatar
As far as I know it will bolt up, you just have to install the correct flywheel to "reach" the torque convertor and I think the holes need to be enlarged to match the bolt pattern of the older convertors. I would do some research to be sure, but I think you can use the 5.3 or 6.0 flexplate with the correct spacer, I think the flywheels have a certain "dish" or offset to them depending on the application...
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 04-19-2012, 03:50 AM   #5
mcmlxix
Collector of Projects
mcmlxix's Avatar
If you're going the extra mile to swap a 5.3L, get the 4L60e that would have come behind that motor. It can all be controlled by the same computer. You can use the NP205 that should have come in your 72, but the input shaft may need to be swapped.
Rich
1972 K5 Blazer CST Click HERE
Old 04-19-2012, 09:10 AM   #6
dme922
dme922's Avatar
As far as adapting the 4l60e to a np205 is the input shaft the only part needed?
Old 04-19-2012, 09:16 AM   #7
Crash_OK
Crash_OK's Avatar
[QUOTE=dme922;5323665]As far as adapting the 4l60e to a np205 is the input shaft the only part needed?
Posted via Mobile Device[/QUOTE
No you will need a adapter to change the rear of the transmission from 6 bolt to 4 bolt, it also adds the extra length needed. In addition you have to modify the transfer case mount and coupler.
You can go to my build for more detail. I think the transmission stuff starts at post #82
http://67-72chevytrucks.com/vboard/s...=494599&page=4
Mark
Crash's 69 4x4 SWB
Old 04-19-2012, 09:31 PM   #8
dme922
dme922's Avatar
Thanks crash. I checked out your post. Do you have any knowledge on adapting a 700r4 in this type of swap. I have one out of a 93 chevy and if this would work i would like to use it to keep from putting out more cash for another tranny.
Old 04-20-2012, 09:12 PM   #9
Crash_OK
Crash_OK's Avatar
The 700r4 will work. I believe you will still need to change the tail shaft and modify the trans to transfer case adapter and coupler.
http://www.advanceadapters.com/categ.../0/0/7/0/28/0/
Mark
Crash's 69 4x4 SWB
