Old 04-18-2012, 09:47 PM   #1
mattpiotr
Headers VS Manifolds?
im running flowmaster original 40s im getting sick of the headers always leaking or spark plug getting burnt, id like to switch to manifolds but i really dont want to loose that good sound? will i really notice that much of a difference in sound and performance? its on a 350 v8
mattpiotr is offline   Reply With Quote
Old 04-18-2012, 09:57 PM   #2
86 K-10
86 K-10's Avatar
Re: Headers VS Manifolds?
use good gaskets, cut the flanges, and use exhaust wrap. my plain-jane steel ones are wrapped and sealed and they run cooler than my manifolds used to. no leaks, no burnt plugs
86 K-10 is offline   Reply With Quote
Old 04-18-2012, 10:24 PM   #3
kelsfine69
18 Till I Die
kelsfine69's Avatar
Im gonna try it but not for a few months yet...Your right headers can be a pita on a driver
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 04-18-2012, 11:44 PM   #4
andrewmp6
What brand headers are they?Cheap ones the main flange will bend with use making them leak.
Old 04-19-2012, 12:00 AM   #5
chevybuilder18
chevybuilder18's Avatar
header gaskets are just a pain, there meant for gasket matching which isnt needed really. Id look for the 6 piece manifold gaskets, they sit right in place on each set of ports. Ive heard these work better. Good luck!
Her name is Quicksilver
1978 Chevrolet silverado, shortbox stepside currently being swapped IN is a LM7 5300 vortec, 4l80E, factory 4.11s, slammed, a dream ride and coined QUICKSILVER
gotta pay $$ if you wanna play
chevybuilder18 is offline   Reply With Quote
Old 04-19-2012, 12:09 AM   #6
chevybuilder18
o Yea i know a solution to your plug wire problems, so ill qoute myself. If your plug wires are getting burnt, id suggest using a different wire holster, with a set of header wires. Save you some time and money go for ACCELs dual core header wires. A buddy of mine has headers on his nova, went a week with not noticing one of his wires was touching the header. Didnt do a thing.
Old 04-19-2012, 01:42 AM   #7
INSIDIOUS '86
INSIDIOUS '86's Avatar
Had some accel 8.8 race wires. They touched the headers for six months with no issues. Also look up REMFLEX gaskets. They will seal 100% of the time all the time. Cut your flanges to allow some flex. And use header lock washers.
If all this doesn't work and your headers aren't warped. I will eat my shoe!!
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 04-19-2012, 01:02 PM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
I just put on 40s @2.25,changed to duals using manifolds,H pipe,on a 305,sounds good
I did grind out those nibs in the manifolds
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 04-19-2012, 05:10 PM   #9
piecesparts
Parts and more parts
piecesparts's Avatar
Where are your leaks on the headers? I have been running headers on my trucks for years and I have found that I can control that problem by doing a couple of simple things. First I use either the copper header gaskets or a set of Felpro header gaskets that are coated with "Coppercoat" high temp sealer. It does work on the headers. I also use the gasket sealer on my collector gaskets and if I have to , I double up the gaskets at the bottom.
Now for a trick that I read in Hot Rod many years ago. Put teflon tape on your header bolts. This simple thing will keep your header bolts from backing out of the heads and when you want them out, the bolts will come out without a lot of effort. When you are ready to use them again, just clean the bolt with a wire brush and put more teflon tape on them. I can put a set of bolts in, heat up the engine and snug them one last time and they last for years. That is IF you have a good quality header flange on your headers to start with.
Frank
