Closed Thread
Old 04-19-2012, 08:33 PM   #3901
bollybib
bollybib's Avatar
Re: What did you do to your truck today!
I made a wastebasket out of a paint container cuz the ashtray is useless with my iPod sitting in it all the time.
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline
Old 04-20-2012, 10:07 AM   #3902
Scott Webster
Sheetmetal Psycho
Scott Webster's Avatar
Took the truck for a little spin to check out the tires and I hear ticking. Time for diagnosis.
I didn't say you were stupid, but I was thinking it... I need a check up from the neck up!
Project "Rigginstine's Monster"
1971 C-10 longbed 355/4spd
Future mods: 67 front clip
Webby's Rigginations - where everything has potential!
Scott Webster is offline
Old 04-20-2012, 11:46 AM   #3903
71tahoe
71tahoe's Avatar
Found out the space between dual headlights makes a good nesting place:
71tahoe is offline
Old 04-22-2012, 09:19 AM   #3904
Hotrob72
Hotrob72's Avatar
Put the new dash pad on, along with the new dash bezel.
Also installed a new hei setup
1971 chevy c10 ECE 4.5/6 dropped
1970 suburban ECE 4/6 Dropped 45K original miles so far
1948 Ford Sedan
1941 Dodge COE
1932 ford roadster
the rest are normal drivers
Hotrob72 is offline
Old 04-22-2012, 09:49 AM   #3905
400smallblock
rehung paasanger side door and front fender after rebuilding front door pillar.lined everthing up. now its time for cab corner inner outer rockers rear pillar repair and cab floor patches. other side needs done too.sometimes it seems like you get a lot done, then the next time you wonder how long its gonna take to finish it.
400smallblock is offline
Old 04-22-2012, 11:09 AM   #3906
midniteblues
midniteblues's Avatar
Found a power wire that was rubbed through next to my battery tray that was plagueing me with a dead battery when left connected ... new wire new battery and its ready for spring cleaning. After the new speedo bullet was put in I no longer have any drips for now
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline
Old 04-22-2012, 02:06 PM   #3907
aventur1
aventur1's Avatar
Installed new brake light switch
1968 4x4 Frame, with a 67 Cab and Bed
A Shorter Step
1999 Dodge 2500 Cummins Diesel
aventur1 is offline
Old 04-22-2012, 06:17 PM   #3908
Shyguy
Junior Member
Shyguy's Avatar
Originally Posted by RossRinSD View Post
Once you start sticking metal together, it opens up the door for all sorts of new projects. You'll be able to make, build, and fix all sorts of cool things.
This was my latest, winch bumper, tow bumper, and rocksliders.
I do have all my rocker panel replacements, just need to find the time and get to work on them.
Great looking bumpers!
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline
Old 04-22-2012, 06:28 PM   #3909
Shyguy
Junior Member
Shyguy's Avatar
Took a few more baby steps on my truck today.
I wire brushed the rain gutter and rear cab upper seam above the back window, then sprayed rust stop stuff in them.
I used the stuff that O'Reilly's store has.
I am still having problems getting my act together, but I finally decided to start at the top and work my way down.
Shyguy is offline
Old 04-23-2012, 04:00 PM   #3910
shopking72
shopking72's Avatar
Test mounting my new Torq Thrust wheels that I got from my brother who had them for his truck which was wrecked almost 8 years ago. Wheels have just sat in the boxes and never been mounted!
20x10 for the rears, and 18x8.5 for the fronts.
I had 2 Nitto Invo 295/35/20 on my Impala project, so I dismounted one of my Coys and put the Invo on the Torq Thrust and mounted to test fit.
Still deciding if the backspacing is right....
1972 C10 LWB- 4.5 Front and 5 Rear Drop, 406/TH350
1966 Caprice
1968 Impala (Frame Off LSX Project)
2001 Tahoe LT
2013 Hyundai Elantra
2010 Kawasaki Z1000
shopking72 is offline
Old 04-23-2012, 04:03 PM   #3911
67cheby
67cheby
67cheby's Avatar
Those look GREAT !
67cheby is offline
Old 04-23-2012, 05:15 PM   #3912
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
nice toy house too!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline
Old 04-23-2012, 05:56 PM   #3913
RexDodge
Since I am "officially" done with the back half (shortened the frame/box, installed lowering coils, installed 2" lowering blocks (shooting for 6" total drop), installed new/improved/relocated panhard bar, relocated upper shock mounts, flipped the trailing arm brackets, beefed up my trailing arms (skip welded and new poly bushings), cleaned and painted all that, built/installed 3" exhaust system with X pipe/DynoMax 2 chamber mufflers routed through the mid cross member and finished up blazer tank install) I ordered my 2.5" drop spindles and 2" lowering coils...yesssss. Time to turn it around in the garage and rip the front end off. Here...we...go! hahahahaha...
RexDodge is offline
Old 04-23-2012, 07:18 PM   #3914
Andy4639
Old member
Andy4639's Avatar
Wink Re: What did you do to your truck today!
Got home from Charlotte NC auto fest yesterday and the PVC valve gormlet had went bad had oil all over the right side of the motor. I put a new one in it today.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Andy4639 is offline
Old 04-23-2012, 08:30 PM   #3915
shopking72
shopking72's Avatar
Originally Posted by 67cheby View Post
Those look GREAT !
Thanks! I am pretty excited!
1966 Caprice
2001 Tahoe LT
2010 Kawasaki Z1000
Old 04-24-2012, 08:02 AM   #3916
Bennett68C10
Bennett68C10's Avatar
Wheels look great, one of my all time favorite wheels
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline
Old 04-24-2012, 11:17 AM   #3917
The Big Green
Have my rear 24's on my bagged truck. The engines out for freeze plug replacement and it'll be going back in this weekend.
The Big Green is offline
Old 04-24-2012, 12:41 PM   #3918
shopking72
shopking72's Avatar
Thanks! Yup mine too
1966 Caprice
2001 Tahoe LT
2010 Kawasaki Z1000
Old 04-24-2012, 04:44 PM   #3919
aventur1
aventur1's Avatar
Installed new seat, recycled leather with cloth inserts
A Shorter Step
aventur1 is offline
Old 04-24-2012, 04:57 PM   #3920
BLOWN72
Try to take off the spare tire holder, couldn't get the bolts to come loose. Sawzall and about 2 minutes and it was off. Took the old nasty headliner out, cleaned the carpets, installed spectre air cleaner with top filter, new floormates, replaced all the lights. Ordered a new piece of trim for the door with clips, saddle seat cover and new dash pad from lmc.
1972 C10 SHORT BED, BLACK ON BLACK, ZZ3 CRATE MOTOR WITH B&M 250 SUPERCHARGER, HEADERS, 350TURBO TRANS, BOOST RETARD, POSI, 373 GEARS
1966 MUSTANG COUPLE, 289 HIPO MOTOR, CAM, 650 HOLLEY CARB, FULL LENGTH HEADERS, 2.5" FLOWMASTER EXHAUST, HURST SHIFTER, 373 GEARS POSI
2006 MONTE CARLO, FLOWMASTER MUFFLERS, K&N INTAKE, EXTERIOR MODS
BLOWN72 is offline
Old 04-24-2012, 05:01 PM   #3921
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
just went for a nice burnout
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline
Old 04-24-2012, 07:23 PM   #3922
wrwelton
wrwelton's Avatar
I finished putting on mudflaps today and put another hour into buffing grill. Should have it all buffed out in another 2 hours. Tough getting 40 years of oxidation off that aluminum. I bought some seals for the door windows and the clips are not located in the right place. Most perplexing. Will have to call LMC and see what is wrong.I will finish grill thursday and install grill and front bumper and take truck for maiden voyage. Finally!! Cant wait.
I know I can! I know i can! 72 K20 Restoration
wrwelton is offline
Old 04-27-2012, 06:32 PM   #3923
Andy4639
Old member
Andy4639's Avatar
Cool Re: What did you do to your truck today!
Well I started by washing it good for the cruise in tomorrow. Then I worked on the drivers side door. I got it where it closes pretty good now but the back bottom still sticks out some. I have new door handles to install, just got them today from Tim Christian , thanks they look great and GM to!
Andy4639 is offline
Old 04-27-2012, 11:05 PM   #3924
Pont406
Nice!
I call that a stress management.
Pont406 is offline
Old 04-27-2012, 11:31 PM   #3925
dliving69
dliving69's Avatar
Latley I have taken the front bumper off my 69 and started sanding it down and is soon to repaint it White, like it is already. Put some floor mats in, Got my Ipod hookups put into my stereo. Added four Kicker speakers in. Tuned the carb, so Its burning rubber now. Next is to find out why my Posi isnt kicking in, and also about to replace the rear main seal and take valve covers off and paint them and new gaskets.
dliving69 is offline
Closed Thread
