Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > Welcome Area
Old 04-11-2012, 07:40 AM   #1
Tutball
Newbie thats in a bind
Hi my name is Rob. I am currently thinking about purchasing a GMC sierra 87.I am 28 years and from Hinesville, GA. I am in the Navy and stationed in Norfolk, VA. I want a fixer upper and I think I found the perfect truck to fix up. This is my first truck purchase and really could use some tips on what to look for when I go inspect the car. The lady wants 1500 for it. Problems that you cant see in the picture are as follow the speedometer doesnt work and the gas gauge doesnt work and also she said I will have to bleed the brakes. No ac or heat. She did state the motor is a beast. Also the rust on the floorboard will that be a big problem to self treat. Any helps and tips would be greatly appreciated. Thanks in advanced.
Tutball is offline   Reply With Quote
Old 04-11-2012, 08:10 AM   #2
ctandc
Re: Newbie thats in a bind
Looks a bit pricey for what it is, but that's just my opinion.
Go to www.searchtempest.com
Plug in what you're looking for and go at it.
____________________________
ctandc is offline   Reply With Quote
Old 04-11-2012, 08:46 AM   #3
Tutball
Appreciate your help.
Old 04-11-2012, 04:52 PM   #4
Clyde65
Clyde65's Avatar
Id agree, looks like a $500 parts truck to me.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-11-2012, 04:57 PM   #5
ctandc
Here ya go:
http://norfolk.craigslist.org/cto/2880922642.html
Old 04-20-2012, 12:00 PM   #6
1ATony
The speedo issue could be a bad cable, and the fuel gauge more than likely would be a bad sending unit.
If the floors are rotted (if you can't do the work yourself) you would need to replace them. body work can add up quick if you have to have someone do it for you. Just things to keep in mind.
1ATony is offline   Reply With Quote
