04-13-2012, 11:13 PM | #1 |
Can't find part
Fuel selector valve, lordco staff here couldn't find it and I chat fint it on any sites,any one know where I can find it
Posted via Mobile Device |
04-13-2012, 11:30 PM | #2 |
Re: Can't find part
Friend of mine Had The Same Problem, Go to RockAuto.com i think he said it was round $113.79 for his 1975 Chevrolet C10 Fuel Tank Selector Valve
04-14-2012, 08:48 AM | #3 |
Robert Olson Transport
Re: Can't find part
i bought mine at auto zone they had it in stock.... Lately i dont know what to make outta these chain auto part stores... i wanted new lug nuts 1/2 X20 you would think i was searching for the hope diamond and i still had to buy a set with locks and a extra card of four
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
04-14-2012, 11:01 AM | #4 |
Square
Re: Can't find part
I got one from napa, had them in stock also.
Squarebody Syndicate |
04-14-2012, 12:07 PM | #5 |
Re: Can't find part
I got mine from NAPA. My local store didn't have it on their shelf, but the warehouse had them.
04-14-2012, 03:04 PM | #6 |
Re: Can't find part
AC Delco part number U7000 has 3 ports that are capped off or U7001 has all 6 ports open.
http://webcaps.ecomm.gm.com/internet...e=22&part=6276 |
04-16-2012, 05:06 PM | #7 |
Dino burner
Re: Can't find part
I thought Lordco carried or could easily get Standard Motor Products (aka Blue Streak) stuff ... if so, FV1 is the regular 3-port switching valve.
04-16-2012, 07:19 PM | #8 | |
It'd be alot cooler if you did
Re: Can't find part
04-16-2012, 07:35 PM | #9 | |
Re: Can't find part
04-16-2012, 10:31 PM | #10 |
Re: Can't find part
Are you sure it's the selector valve that's bad? I thought mine was bad on my '78 and I couldn't find a six port anywhere. Turns out, it wasn't the selector valve after all, it was actually the selector switch on the dash that wasn't letting enough juice get through to engage the solenoid in the selector valve. Saved me about $100. Worth double checking if you haven't already.
1964 Chevrolet C10 SWB Stepside (350cid/TH400) 1978 Chevrolet C10 SWB Silverado Big 10 (454cid/TH400) -"Ah, the pressure's fierce!" |
04-17-2012, 12:25 AM | #11 |
BAD BOW-Silverado XST
Re: Can't find part
www.jcwhitney.com has them.
04-17-2012, 02:18 PM | #12 |
Moderator
Re: Can't find part
On the single wire 73-8? trucks... You can use a quality DPDT ON-ON toggle switch like McMaster Carr #7343K821 in place of the darn poor excuse for a switch that GM chose. You'll need to cut off one corner terminal to use the 5 position GM factory plug because the 6th hole is blocked.
This is the 6 port AC Delco solenoid valve. http://www.amazon.com/ACDelco-467513-Fuel-Selector... Summit Racing lists the 3 port Standard Motor Products FV1. Unfortunately the U7000 & U7001 as well as the valve listed for the 77 at Rock Auto are actually the later 1980s plastic 6 port Motorized Pollack unit. The motorized Pollack is not a drop-in unit. You'll need to replace/modify the entire tank switch and fuel gauge harness to make it work. Rock Auto is generally good to deal with but this should be noted in the information for this part... Last edited by hatzie; 04-17-2012 at 02:23 PM. |
04-17-2012, 07:26 PM | #13 |
Re: Can't find part
What's the differnces between 3 port and 6?
04-17-2012, 08:17 PM | #14 |
Re: Can't find part
One tank or two tanks!
04-17-2012, 08:28 PM | #15 |
Re: Can't find part
How can u tell the difference
04-17-2012, 09:05 PM | #16 |
Re: Can't find part
There's a pic of it after I pulled it out Posted via Mobile Device |
04-17-2012, 11:52 PM | #17 |
Dino burner
Re: Can't find part
That looks like a 3 port to me.
One inlet comes from the driver's side tank. One inlet comes from the passenger's side tank. The outlet goes to the fuel pump mounted on the engine. |
04-18-2012, 06:26 AM | #18 |
Re: Can't find part
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
04-18-2012, 05:33 PM | #19 |
Moderator
Re: Can't find part
3port switches supply lines.
6port switches supply & return. |
04-18-2012, 09:56 PM | #20 |
Re: Can't find part
04-21-2012, 10:10 AM | #21 | |
Re: Can't find part
04-21-2012, 10:14 PM | #22 |
Re: Can't find part
Well I pulled it already and by passed it for now and I plan on renewing the whole system for that I just couldn't find the selector valve any where but plan on buying the Valle then the switch and wire all in at once, everything is slashed up with the wires on that truck so time for new all around I think
