Closed Thread
Old 04-20-2012, 09:24 PM   #651
LDO
LDO's Avatar
Re: What Did You Do With Your Truck Today ?
I put on some new 'shoes' on the ol' girl. 15x8 Rallys on 245 60 15s. I am happy, happy!!
LDO is offline
Old 04-20-2012, 09:34 PM   #652
Rudoo
Looks good Bob!
Rudoo is offline
Old 04-20-2012, 09:49 PM   #653
LDO
LDO's Avatar
Thanks!
It finally looks like it does in my head!
LDO is offline
Old 04-20-2012, 10:20 PM   #654
55Cameo
55Cameo's Avatar
Pulled the motor ans trans out today
Build thread:55 Cameo R!! http://67-72chevytrucks.com/vboard/s...d.php?t=519851
55Cameo is offline
Old 04-21-2012, 07:19 AM   #655
Russell Ashley
Russell Ashley's Avatar
Removed my rear fenders in preparation to working on my bed. I didn't like clutch head bolts before, now I really really don't like them, LOL.
Bob, looks great. Nice improvement IMO.
Russell Ashley is offline
Old 04-21-2012, 08:48 AM   #656
youngrodder
youngrodder's Avatar
I started installing my carpet and worked on my speaker pods that go into the kick panels. I also finished wiring up my interior lights through the door jam switches.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline
Old 04-21-2012, 10:02 AM   #657
Speedbumpauto
Speedbumpauto's Avatar
Fenders and bed installed on frame.
Speedbumpauto is offline
Old 04-21-2012, 07:24 PM   #658
lowdownstar
big guy
lowdownstar's Avatar
Man that thing looks like a beast!!!!! can't wait till you have it all together
Ray
lowdownstar is offline
Old 04-21-2012, 07:58 PM   #659
55Cameo
55Cameo's Avatar
That looks real nice. Like the fat meats in the rear!
55Cameo is offline
Old 04-21-2012, 08:07 PM   #660
Speedbumpauto
Thanks, guys. It's a hot rod.....ya can't have too big a tire or too many carbs!
Old 04-21-2012, 08:13 PM   #661
Kabwe
Certified Car Nut
Kabwe's Avatar
Speedbump,
That thing looks wicked. I likes. Good job man.
Kabwe is offline
Old 04-21-2012, 09:18 PM   #662
shadow1967
shadow1967's Avatar
Speedbump, Looks cool! Love what you did with the paint on the body line difference. I dislike the curved down line, no imagination.
shadow1967 is offline
Old 04-21-2012, 10:15 PM   #663
oldcouple
oldcouple's Avatar
Detail work, painted the dash with wrinkle paint,, inside steps with spray bed liner, detailed door jambs, took the bed off to begin painting the frame and install the new gas tank. Discovered my cross member that the shocks bolt to is bolted in, instead of riveted, one sides bolts were loose, so thinking new grade 8s and nylocks may keep that from happening again.
Retired and too busy to work.
oldcouple is offline
Old 04-22-2012, 12:21 AM   #664
OrrieG
OrrieG's Avatar
Worked on the steering wheel. Got the horn adaptor figured out and fabbed. Dremmeled out the cracks in the steering wheel. Tomorrow will epoxy and start sanding it. I will post details in my build thread.
OrrieG is offline
Old 04-22-2012, 07:18 PM   #665
Rude Dude
Rude Dude's Avatar
More sanding on my $40 manifold, I included the before pic as well , almost ready to polish
Rude Dude is offline
Old 04-22-2012, 11:34 PM   #666
youngrodder
Started install my jute pad and carpet. I have a center console that will cover the seam in the middle. I also test fit one of my speaker pods. Car show in (2) weeks so I'm in trash mode...ha ha
Marc
Old 04-23-2012, 12:21 AM   #667
lazerstrouts
Fixed all the grounds on my tahoe chassis so the old beast has 4wd and brake lights again.
lazerstrouts is offline
Old 04-29-2012, 09:24 PM   #668
OrrieG
OrrieG's Avatar
Sanded the steering wheel first epoxy coat and applied second. Worked on cleaning up the tailgate cable bracket welds. Guide coated and blocked the bumpers. Feels like progress.
OrrieG is offline
Old 04-29-2012, 09:27 PM   #669
shadow1967
shadow1967's Avatar
Well, I made a MESS!!
Old 04-30-2012, 09:50 AM   #670
handyhands
I have been cleaning out the wheel wells, angle grinder with heavy wire wheel.
works pretty good, plan to use it on the bottom of cab as well. 53/s10
handyhands is offline
Old 04-30-2012, 09:56 AM   #671
youngrodder
I finished one speaker pod and mounted the speaker. I'm working on the driver side now. This was my first attempt at making fibergalss speaker pods. I learned a lot.
Marc
Old 04-30-2012, 06:28 PM   #672
Daze57
Daze57's Avatar
very nice work
Daze57 is offline
Old 04-30-2012, 06:48 PM   #673
Amorget
Spent nearly $1,000 in parts today buying everything from cab corners to bed mounts. Fingers cross that the bulk of the buying is now done.
For my and my wife's birthdays (we are only a couple weeks apart) her family bought almost all of the exterior lighting for the truck, so that is exciting, too!
Amorget is offline
Old 04-30-2012, 07:58 PM   #674
51 okie
Active Member
NIce fiberglass work Youngrodder. Looks great.
51 okie is offline
Old 05-01-2012, 11:38 AM   #675
youngrodder
Thanks man, I learned a lot. I still need to make a cover to cover up my computer for my engine seen in the pic. I also need to figure out the back of the cab.
Marc
Closed Thread
