O.T. Olds Aurora
I need a back and forth to work car that I can shove a couple of car seats into, and today we looked at a 95 Aurora with 82,000 miles for $5,900.
It seems to run and drive okay, but I'm a little leery about future parts costs, as well as wondering how hard the darn thing will be to work on. There's sure not a lot of elbow room under the hood since it's a front wheel drive V8 Does anyone here have any experience with these cars? Anything good or bad that I should be aware of? Thanks in advance for your input! TS
I can do all things thru Christ, but he evidently doesn't want me to beat that Camaro light to light.... |
Car Knocker
are you sure its a v8. Last one I worked on had the quad 4 in it. Other than that, I don't have an opinion. If it does have a v8, and you are just looking for a comuter car, gas milage might suck.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit. |
"Ochre Ogre"
That should be the 4.0 V-8 that is based on the Northstar engine in the Cadillacs. It has been a very reliable engine from what I have seen with my friends 95 Aurora. He got over 200,000 miles on it with out any problems. One thing you should think about is if it does break down, you can count on all the parts being very expensive.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
Why don't you pick up a used 94-96 Caprice or 9C1 police car? They have 260hp LT1's, OD tranny's....they are big...roomy....get 18-22mpg on the highway and you can usually find them cheap.....there are a ton of parts for them....I bought mine for $3000.
FocuzTech Performance Evergreen Protective Coatings Gatorhyde...the best kept secret in spray in bed lining & protection Last edited by miket; 09-20-2003 at 11:34 PM. |
Expensive to repair unless you can do the work yourself. My brother in law is a mechanic and he was telling me about working on the Aurora. They had one in with a bad pan gasket and had to pull th engine and transmission out of the car and separate them in order to change the gasket. He said the exhaust wraps in under the pan and you can't get it off unless you separate the engine from the transmission. An expensive labour bill for a minimal repair item.'
Find yourself a clean late model Toyota Camry or Honda Accord.
1968 Chevy - 292 with a powerglide |
![]() ![]() Join Date: Jul 2003
Those first generation Auroras are nothing but a problem waiting to happen.
I have seen many of them at the auctions, but they had a lot of electrical issues. The 4.0 is peppy when it runs right, but super expensive to fix. People don't want them, as to why the price is so low. I too agree a great daily driver is a 9c1 Caprice with the LT1. They are a great car with one weak spot being the 4l60E. ![]() Once a compentent tranny guy rebuilds them they are fine, but right out of the GM factory they are failure prone. Mine has 170k miles and looks and runs like new. Definitely one of the last great GM cars. |
I routinely drove my 95 caprice, impala ss and now my 9c1 to 200k without tranny rebuilds or major repairs......
FocuzTech Performance Evergreen Protective Coatings Gatorhyde...the best kept secret in spray in bed lining & protection |
