Closed Thread
Old 04-22-2012, 03:58 PM   #5101
62 Barnfind
62 Barnfind's Avatar
Re: What did you do to your truck today?
Installed the hood and did a little aligning.
62 Barnfind is offline
Old 04-22-2012, 07:02 PM   #5102
robber grin
Pulled the original 235 and 4 speed.
robber grin is offline
Old 04-22-2012, 07:02 PM   #5103
kenmel
kenmel's Avatar
pulled the sh!%@y buckets out with their WOOD mounts!! and test fit the bench, was supposed to be a 67-72 but the mounting bolts are nowhere near the holes
kenmel is offline
Old 04-22-2012, 07:13 PM   #5104
robber grin
Red face Re: What did you do to your truck today?
Forgot the pictures...
Old 04-22-2012, 07:55 PM   #5105
lwb66step
lwb66step's Avatar
went out to a local spot and popped some pics. check it out...these were my favs. Sorry, I like pics...
1966 LWB Stepside......SOLD
1963 SWB Fleetside.....Current Project
I hate all fords.
lwb66step is offline
Old 04-22-2012, 08:31 PM   #5106
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
You won't get any complaints from anyone on here for posting pictures! Well...unless you are posting F@rd pictures that is!
Jason
1960 GMC 4x4 Babe (the Blue Ox) - Build Thread
chevy_man5 is offline
Old 04-22-2012, 08:38 PM   #5107
lwb66step
lwb66step's Avatar
I hate all fords
I hate all fords.
Old 04-22-2012, 10:19 PM   #5108
dantimdad
dantimdad's Avatar
I got the cowl covers all welded into one piece and started sand blasting them. I am going to cut out the cowl grill and smooth it next.
The pics turned out terrible. Will take more soon.
After smoothing I will start on the inner fenders and radiator support.
Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla
Matt. 6:27 "Who of you by worrying can add a single hour to his life?”
http://www.67-72chevytrucks.com/vboa...=507266&page=2
dantimdad is offline
Old 04-22-2012, 10:35 PM   #5109
CRGRS 66
CRGRS 66's Avatar
lwb66, I love the black and white pic! Nice composition
CRGRS 66 is offline
Old 04-22-2012, 10:46 PM   #5110
AngryPirate
AngryPirate's Avatar
replaced my single pot master cylinder with a dual. New lines, hoses, cylinders and shoes. Nothing too thrilling, but it's what I did. ;-)
Man do I hate bleeding brakes. Do not buy the Mityvac 8500. It just doesn't work well for bleeding.
AngryPirate is offline
Old 04-22-2012, 11:26 PM   #5111
mud.man.rj
mud.man.rj's Avatar
Worked on more bodywork tonight, finished cab corner and outer rocker, seam sealed amd primed, next door guts back in then only the rest of the body, haha.
mud.man.rj is offline
Old 04-23-2012, 12:14 AM   #5112
64shortbox
64shortbox's Avatar
If you're still having problems bleeding your brakes you might try this - providing you have the junk lying around that is. I did this on the company bucket loader and my 64 C10 & it worked great.
Cut a piece of plate that will just cover the top of your master cylinder, drill & tap a hole in the middle of the plate to 1/4" pipe thread, Clamp the plate to the master cylinder using a couple of small C clamps or light chains with long threaded bolts that will fit between the chain links & nuts and cinch down, install a small regulator & gauge with a quick connect, run an air hose from your compressor to the regulator and set the regulator to 10 PSI MAX!! Start bleeding your system but don't let the master run dry. Check it often.
I know, if you can't get your hands on all the junk needed to do this it sure doesn't help you much. But it sure makes bleeding the brakes an easy task.
64shortbox is offline
Old 04-23-2012, 12:23 AM   #5113
Ta2Don
Ta2Don's Avatar
I'm new to this board and loving every minute here. Thank you to everyone for their posts, been researching ideas since deciding to get a project going. My new toy is a 65 SWB Stepper, she arrived home yesterday morning and by the next evening I went from assembled truck to partially disassembled. Pulled the bed, hood, and front fenders. Tomorrow, get the remainder of the front cap off, and gut the interior.
Ta2Don is offline
Old 04-23-2012, 12:26 AM   #5114
64shortbox
64shortbox's Avatar
You're sure not wasting any time getting started!!!! Great find by the way.
Old 04-23-2012, 12:30 AM   #5115
markeb01
Senior Enthusiast
markeb01's Avatar
Welcome to the forum. Nice looking truck. Hope you're taking lots of pictures!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
markeb01 is offline
Old 04-23-2012, 12:57 AM   #5116
Ta2Don
Ta2Don's Avatar
Thanks for the welcome and encouragement, and the truck was originally purchased here locally by the Public School System. I have the original Protect-O-Plate and bought the truck without an engine and someone had installed a TH350 tranny. Buying a 91 350 and plan on a 5 speed stick. A friend has a donor 84 for suspension, planning on swapping to the newer Diff and getting dropped springs for front and rear. Lots of pics are part of the process.
Ta2Don is offline
Old 04-23-2012, 12:57 AM   #5117
64shortbox
64shortbox's Avatar
I finished assembling my front suspension today - well with the exception of the calipers and ceramic pads. I bought a complete suspension out of an 85 C10 over a year ago, I took it to work, broke it down, steam cleaned it, pressed out the old lower ball joints & all the bushings, media blasted everything, painted it all, pressed in new Poly bushings & new lower ball joints (thank goodness we have a 100 ton press at work) I took the pieces back home for final reassembly, it's too hard to move in one piece. I added CPP 2 1/2" drop spindles & CPP 6 lug rotors, I used Raybestos Professional Grade Ball Joints, Moog standard rate springs & the control arm bushings are Energy Suspension pieces, the sway bar is 1 1/4" & came from a 1 ton 76 truck, all in all I've got over $1,000.00 wrapped up in this and I don't know when I'll get around to getting it all installed. Oh, I even made a little stand for the suspension saddle that just fits my floor jack so I can pick it up, move it around & jack it into place by myself. (In theory anyway)
Old 04-23-2012, 01:02 AM   #5118
markeb01
Senior Enthusiast
markeb01's Avatar
Nice progress. That's going to be a nice upgrade once it's in the truck. I had a similar stand under mine made of wood that allowed me to move it around with a jack. Certainly was convenient.
markeb01 is offline
Old 04-23-2012, 01:11 AM   #5119
raic65
raic65's Avatar
Got this brake setup mocked up and hopefully will be installing it this weekend.
raic65 is offline
Old 04-23-2012, 01:15 AM   #5120
64shortbox
64shortbox's Avatar
Mark,
Thanks for the good words. I sure hope it rides well when done. Everything is new, even the bearings, spindle nuts, washers & dust caps. I'm hoping I'll be long dead and buried before it wears out and it will be someone eleses problem. (One of the grandkids LOL)
Old 04-23-2012, 01:16 AM   #5121
64shortbox
64shortbox's Avatar
Now That is SWEET!!!!!!!!!!!!!!!!!!!
Old 04-23-2012, 09:17 AM   #5122
vin63
It's Better With Nitro
vin63's Avatar
...added about 20 pounds of weight to the cab yesterday. I figured since I will no longer be drag racing the truck, I might as well make it more comfortable...
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline
Old 04-23-2012, 09:21 PM   #5123
Mike Honcho
Mike Honcho's Avatar
Stopped on the way home from work and put 40 dollars in the gas tank.
Mike Honcho is offline
Old 04-23-2012, 09:29 PM   #5124
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
And that got you home? How are you going to get to work tomorrow?
Jason
Old 04-23-2012, 09:32 PM   #5125
CRGRS 66
CRGRS 66's Avatar
very nice looking install on the insulation, what did you use?
CRGRS 66 is offline
Closed Thread
