Closed Thread
Old 04-23-2012, 09:37 PM   #5126
CRGRS 66
CRGRS 66's Avatar
Re: What did you do to your truck today?
Maybe not the place to do this, but I posted a request for advice on suspension upgrades, got a few repsonses, would appreciate a greater variety of opinion if you guys wouldn't mind checking out my thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=520865
Thanks,
Craiger
CRGRS 66 is offline
Old 04-23-2012, 09:58 PM   #5127
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
Pulled the Chevy bedside off my 66 GMC and put a GMC side back on.
Worked on my wifes 63 and my 63 too.
Cleaned the work area and put away all the tools.
Finally made it to over 100 degrees... summer is a coming....
I love the heat..
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline
Old 04-23-2012, 10:38 PM   #5128
Ta2Don
Ta2Don's Avatar
Got the rest of the front cap off today, and stripped out the interior, now the real work begins. Next stop, suspension upgrades... Calling it a night guys.
Ta2Don is offline
Old 04-23-2012, 10:57 PM   #5129
K5 Addiction
K5 Addiction's Avatar
Not too much, put some new pedal pads & a new peep mirror.
K5 Addiction is offline
Old 04-24-2012, 08:10 AM   #5130
jbgroby
jbgroby's Avatar
Your truck with teh blue trip in excellent. The way the rims and trim seems to bring out the Ivory/White (don't tell whihc) really makes it pop.
Damn nice.
jbgroby is offline
Old 04-24-2012, 08:54 AM   #5131
vin63
It's Better With Nitro
vin63's Avatar
Originally Posted by CRGRS 66 View Post
very nice looking install on the insulation, what did you use?
I had an old Damplifier Pro kit from Second Skin I bought a long time ago. The new kits have the black foil.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline
Old 04-24-2012, 10:06 AM   #5132
K5 Addiction
Thanks man, It's coming together.
Damn nice.
Old 04-24-2012, 10:11 AM   #5133
XtechX
XtechX's Avatar
I agree, I really like the blue because it looks great and its a bit different.
Opportunity usually comes disguised....As hard work!!!
XtechX is offline
Old 04-24-2012, 11:12 AM   #5134
66-PMD-GMC
66-PMD-GMC's Avatar
Where is Edmore in Michigan? I am going there this summer. Visiting family and taking some parts to my cousin in the U.P.
Projects..
440CID 2X4 Pontiac
Old 04-24-2012, 11:13 AM   #5135
66-PMD-GMC
66-PMD-GMC's Avatar
Sorry meant to send a PM...
Nice truck..
Projects..
440CID 2X4 Pontiac
Old 04-24-2012, 12:40 PM   #5136
doobiebro
doobiebro's Avatar
Originally Posted by 64shortbox View Post
I finished assembling my front suspension today - well with the exception of the calipers and ceramic pads. I bought a complete suspension out of an 85 C10 over a year ago, I took it to work, broke it down, steam cleaned it, pressed out the old lower ball joints & all the bushings, media blasted everything, painted it all, pressed in new Poly bushings & new lower ball joints (thank goodness we have a 100 ton press at work) I took the pieces back home for final reassembly, it's too hard to move in one piece. I added CPP 2 1/2" drop spindles & CPP 6 lug rotors, I used Raybestos Professional Grade Ball Joints, Moog standard rate springs & the control arm bushings are Energy Suspension pieces, the sway bar is 1 1/4" & came from a 1 ton 76 truck, all in all I've got over $1,000.00 wrapped up in this and I don't know when I'll get around to getting it all installed. Oh, I even made a little stand for the suspension saddle that just fits my floor jack so I can pick it up, move it around & jack it into place by myself. (In theory anyway)
Nice work 64shortbox.......its coming together
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline
Old 04-24-2012, 03:49 PM   #5137
Hagelin
Hagelin's Avatar
From ready and painted to hours of paint thinner... just because they put the swedish sticker on the wrong primer...
Hagelin is offline
Old 04-24-2012, 07:24 PM   #5138
CRGRS 66
CRGRS 66's Avatar
ugh
CRGRS 66 is offline
Old 04-24-2012, 07:30 PM   #5139
CRGRS 66
CRGRS 66's Avatar
Picked up a couple of blank keys, and a headlight switch at Antique Chevrolet Parts, looked, and looked, and looked for the clip I have misplaced for the throttle linkage, little dickens is hiding somewhere, will have to fashion a new rod so that I can drill the end, and use washers, and a cotter pin.
Scouring Spaenaur, and McMaster Carr at the moment, any ideas where to find. none of the jobbers, or ACP have this little guy
CRGRS 66 is offline
Old 04-24-2012, 08:10 PM   #5140
junk4cash
junk4cash's Avatar
Got my rusty chrome American Racing wheels back from powder coat and went over the entire truck with Penetrol to seal the rust and give it a bit of a gloss. No more dusty rust.
junk4cash is offline
Old 04-24-2012, 09:25 PM   #5141
Raked 64
Raked 64's Avatar
I am in the process of reassembling my 64 shortbed fleetside. I fired the 406 SBC last week and it smoked like a coal burner. Engine had been sitting for 3 years. (this truck restoration has been a 20yr process)
So after all of the time and attention to detail. I pulled the engine and tranny back out to disassemble the freshly painted engine and find out why #7 hole is spewing oil.
I guess an oil ring is stuck. Really stinks as this engine has 20 min on it!!
I am so close to finishing this thing! Assembly is torture! lol
Raked 64 is offline
Old 04-24-2012, 11:14 PM   #5142
monolith
Zero Albedo
monolith's Avatar
Vacuumed out the big panel, did some test fitting for the storage benches for the back, flushed the radiator and refilled with new coolant for summer. Installed new temp gauge, installed new gas gauge, hooked up the speedo, pulled the front bumper. It's nice to be back working on the trucks again.
Baz
"Deserve's got nothin' to do with it."
66 GMC 1500 wideside longbed 250 4spd "Project Rekker"http://67-72chevytrucks.com/vboard/s...d.php?t=467467
65 GMC 1Ton Panelhttp://67-72chevytrucks.com/vboard/s...32#post4794432
65 Chevy Panel (former U.S.Navy truck)
64 Chevy Suburban Carryall 4x4http://67-72chevytrucks.com/vboard/s...d.php?t=358348
64 GMC 1000 wideside longbed 305 4spdhttp://67-72chevytrucks.com/vboard/s....php?p=3600890(Rip- parts truck now)
68 Dodge Charger
monolith is offline
Old 04-25-2012, 11:30 AM   #5143
Raked 64
Raked 64's Avatar
I worked on the interior last night as well. Trying to get the seat belts fitted and test fit the carpet and door panels etc.
I am thinking about wrapping the door panels in black vinyl?
Raked 64 is offline
Old 04-25-2012, 01:52 PM   #5144
3rd Coast Z
3rd Coast Z's Avatar
I got my bed a little closer to level and adjusted the panhard bar so I can drive higher. Also removed my instrument panel trying to figure out how to do the gauges.
3rd Coast Z is offline
Old 04-25-2012, 03:38 PM   #5145
62 Barnfind
62 Barnfind's Avatar
Installed my u-joint, painted the drive shaft and re-intalled. I also filled the holes from the gun rack I removed.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline
Old 04-25-2012, 04:45 PM   #5146
Ta2Don
Ta2Don's Avatar
Hey Raked 64,
What steering column are you using?
Ta2Don is offline
Old 04-25-2012, 04:58 PM   #5147
CdM
CdM's Avatar
Busting 46 years of caked up tranny fluid and dirt off the btm of the cab.. fun fun
Build Thread 66 custom cab lwb http://67-72chevytrucks.com/vboard/s...d.php?t=465726
66 fleet lwb- In process
64 k10 10inch lift 38.5's- In process
92k1500 400hp on 38.5-parts truck now 8(
CdM is offline
Old 04-25-2012, 05:01 PM   #5148
E911manager
Halfway through a Scotts BBW install (What a great guy to deal with!!!).. Hope to finish it in a couple of days...
My Build CAPRICKUP 1964 Chevy SWB on a 94 Caprice
http://67-72chevytrucks.com/vboard/s...d.php?t=492640
E911manager is offline
Old 04-25-2012, 05:08 PM   #5149
dallas71
dallas71's Avatar
tore down the front clip of my truck and now i find out that a replacement core support is a necessity!! that is what happens when you start tearing down...!!
dallas71 is offline
Old 04-25-2012, 08:25 PM   #5150
markeb01
Senior Enthusiast
markeb01's Avatar
Is this what you are looking for:
3/16:
http://www.summitracing.com/parts/RNB-118-045/
5/32”
http://www.summitracing.com/parts/RNB-118-005/
Perhaps having a Dorman part number will help you find one clip locally instead of 25 which you'll probably never use. Summit has more listed. They range from 1/8" to 5/16".
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
markeb01 is offline
Closed Thread
