#76 |
![]() Join Date: Jul 2010
Re: 71' Blazer Rust bucket build
#77 | |
Equal opportunity joke ofender
![]() Join Date: Oct 2011
Vinyl has come a long way in the last five years or so.
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
#78 |
I want to take the image of that script, and lay it on a flat surface of another valve cover. Ill take a pic. of where i want to put it
#79 |
Richard, here is the surface that i want to put the corvette script on....
#80 |
Jim,
I sent you an email Richard
#81 |
Thanks for your quick response, that looks great....do you have anything on file for chevrolet
#82 |
I am pretty sure I have a few different ones. WHat did you have in mind
#83 |
Well, my presents came two days earlier than expected. FedEx as usual appears to have played soccer and other contact sports with the packages. All 3 boxes were busted up and it looked like parts should be missing. I started opening the boxes and he guy asked me what I was doing........I said duh......if you think I am signing for this without checking to make sure everything is still here you have lost your mind. He says well once you open the boxes you can't send them back. I felt like smacking hiim on the forehead and sayin hey stupid unless ur blind the boxes are alread open caused by you and FedEx. I told him I had no intention of sending anything back but if it was missing parts we would be filling out some paperwork before I signed anything. Looks like both of my floorpans are bent but not unuseable. Suprisingly everything survived. I now have a wall full of parts that I can use to start rebuilding the green machine. I hope to get a start on it tomorrow night. I have my work cut out for me but I think it will be worth it. Originally this was going to be a quick rust repair, get it running and drive but since I scored the really nice floor looks like it will end up frame off. Oh well may just go get that rotisserie at Greg smith. Sure will ake the rocker work go easier. I will be able to tell more tomorrow night I hope.
#84 | |
#85 | |
BTW Ed, how you making out with yours? Any progress since u got the top off?
#86 |
Hey Richard at the rate I am going you will be done 1st....I got the windshield out...doors off...dash torn apart ...cleaned drip rail ...primed -floor, dash, jambs, and windshield. Used Sika 1a polyurethane caulk for seam sealer and drip rail. tore 1 door apart started to prep for paint.... New door hinge pins. , I need a book (Rebuilding old blazer 4 DUMMIES). Lots of details. putting it all back together could be interesting...Ed.
#87 | |
#88 |
Jim,
I will look and let you know later today Richard
#89 |
Well got a chance to spend a few hours on the blazer tonight. Original plan was to do the rocker boxes and supporting pcs. first then tackle the rear floor, then the driver windshield pillar. My line of thinking was to keep the doors closed and the top on until the rocker area was done. After getting the rocker box out I see that it aint gonna happen that way.It appears to me that I am going to have to take the top off and rear quarters and get the rear floor replaced first. The wonderful engineers at GM made it so you cant get to two of the bolt heads to remove the inner panels unless you remove the quarter panels including the B pillar. looks like I may as well go ahead and tear the whole rig down and start from scratch. It i the only way I see to get to everything and do it right
#90 | |
wish i lived closer, but it looks like you have things under control
#91 | |
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. Last edited by richard2717; 04-25-2012 at 03:59 PM. |
#92 |
I just got done most of the same build your going to do. I left the top on and did the A pillars, floors, inner rockers and boxes before removing the bed and quarters. I removed the cover on the B pillar to get to those two bolts hidden in there and also fix the step/floor support. Here's my photobucket link for lots of pics.
http://s47.photobucket.com/albums/f1...zer/?start=all ![]() ![]() ![]() ![]() |
#93 |
Thanks for the link John. Are you interested in the aluminum rims we were talking about when you were down?
#94 |
I'm going to go with the factory steel wheel and hubcap look, I picked up two 16.5x9.75 kelsey hayes wheels from Duallyjams.
#95 |
Hey Richard ...Are you going to put new mounts on then work up from there..Here is the link to body bolt replacement...and a photo from LMC on the pieces required....Ed......http://67-72chevytrucks.com/vboard/showthread.php?t=439583[/url]
#96 |
To answer your question I think my set came from N. Carolina 15 years ago Energy suspension #3.4110 or 3.4110R (for Red) double check make sure that's it. Lots of places on-line seem to have these for under $100.....Ed.
#97 | |
I remembered seeing the ones on your Blazer and knew they were not originals then when I saw the ones on Ebay it got me questioning myself LOL I ordered my por15 today so I can coat the inside of all the panels good and I am going to order all new bolts & bushings in the morning so hopefully I can get it all together to replace everything next weekend. Once I get all that in then I can finish tearing the rocker area apart. Richard
#98 |
Well got my bushings and bolts ordered so hopefully they will come in this week.
While trolling Craigs list last night I came across an add for some rallies with new center caps for a decent price I called the guy this morning and set up to meet him this afternoon. He also had this sweet set of polished slots complete with centercaps & lug nuts I picked up for possible installation on the 68' panel.
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. Last edited by richard2717; 04-30-2012 at 06:40 AM. Reason: Fell asleep with laptop in lap and hit several buttons while asleep |
#99 |
VA72C10
![]() Join Date: Mar 2008
did you get the slots and rallies from the same guy? Nice haul!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#100 |
Actually yes I did. Story is he went to Carlile and picked up a set of vette rallies for the 69' shortbed Fleet he just bought . He did not know about this site so I invited him to stop on by. Told him anything he may need or need to know he will find right here.
