Old 04-23-2012, 12:03 AM   #1
1986c10
1986c10's Avatar
Shackle flip and rear pinion angles
Hi, i picked up a 95 chevy ecsb a few months ago. id like to lift it and have been reading up alot about rear shackle flips and id like to try it out. In my thinking though, if a shackle flip were done to the rear spring mount, it would drop only the rear of the springs and the front mount would stay in the same location. Wouldnt this drop to only the rear mount change the pinion angle of the rear end drastically? Or am i over thinking it? Thanks in advance.
1979 C10 - swb, mild 327, restoration project
1979 Mustang - Turbo 5.3 / 4l80e
1976 K20 - Mild 396, 6" lift, 35's - sold
1986 C10 - lwb vortec 355- sold
1982 C10 - swb project- sold
1986c10 is offline   Reply With Quote
Old 04-24-2012, 08:33 AM   #2
Re: Shackle flip and rear pinion angles
I would think it would retain a more correct angle compared to a spring or block lift. Picture it as the axle housing simply pivoting on the front hanger,as the springs are designed to do in normal suspension cycling.
Old 04-24-2012, 02:40 PM   #3
1986c10
1986c10's Avatar
well my thinking is with like a block lift, the stock pinion angle is retained because the axle is not moved any direction but farther below the springs and is not tilted any direction, just lowered so the 3 degree range between output shaft and pinion angle would be kept true. in a shackle flip setup, the eyehook of the rear part of the leafspring is lowered by 5-6" and id think that the lowering of only the rear would make the perches of the axles sit at a much different angle then stock... You probably are correct as many companies make this lift with no problems, i just wanna make sure before i dive into anything
Old 04-24-2012, 02:57 PM   #4
SunSoaked
SunSoaked's Avatar
Actually, just moving the axle down does change the pinion angle. It is pivoting around the output shaft of the fixed yoke (t-case or otherwise) on a long arc. The lower the axle goes the steeper or greater the angle. Think of the opposite. If you lift the axle to the same height (assuming diff is parallel) as the t-case, all the yokes would be in a straight line aka-zero offset. The further the axle moves down the more the pinion on the diff needs to be raised to maintain the same angle in relation to the t-case (or fixed pinion).
SunSoaked is offline   Reply With Quote
Old 04-24-2012, 03:12 PM   #5
Mr. 250r
Mr. 250r's Avatar
My brother used ORDs shackle flip in order to get rid of the block and it ended making his angle just right but he also has shims and he thinks it moved the axle forward that's also with a slip yoke 205 so I guess on a fixed yoke it would stay in the same place
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC LB DRW - Sold
2003 1500 Silverado - Selling
2004 Ram 3500 5.9 H.O NV56 CC LB DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LB SRW
Mr. 250r is offline   Reply With Quote
Old 04-24-2012, 03:20 PM   #6
1986c10
1986c10's Avatar
I see what youre saying but correct me if im wrong, if the rear were lifted but the angle of the pinion stayed the same. The angle between the pinion and driveshaft as well the output shaft and driveshaft would be increased but the actual angle of the pinion and output shaft would be the same because neither were tilted. And from what ive been told, the angle of the pinion to the driveshaft and output to the driveshaft shouldnt be over 7 degrees and their shouldnt be more than a difference of 3 degrees between the two.
Old 04-24-2012, 03:24 PM   #7
1986c10
1986c10's Avatar
Thanks for the input so far guys. Reading back, my stuff sounds really confusing. I'll try to draw some crappy pictures and upload them to help illustrate what im saying haha. Thanks
Old 04-24-2012, 07:01 PM   #8
Prerunner1982
Prerunner1982's Avatar
As Mr250r said... use 2* or 3* shims to get the pinion angle straight again. No reason to over think it...
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 04-24-2012, 07:04 PM   #9
SunSoaked
SunSoaked's Avatar
I think the angle has to change. Its the relation between the attachment points on each end that matter. Put a digital angle finder on your head and note the angle while sitting on the couch looking at the center of the TV. Now stand up and looking at the same spot see if its different. I'm betting when standing your chin is lower (assumimg your eyeballs stay fixed in their sockets..lol). The fixed yoke on the t-case represents the TV-it never moves. Your mellon represents the diff-it only moved up (or down). The angle of your eyes HAD to change in order to maintain the relationship or you would be looking at the top (or bottom) of the TV.
Kind of cheesy but hopefully illistrates my point.
Old 04-28-2012, 01:26 AM   #10
Psycho71
Psycho71's Avatar
The shackle flip does help retain the pinion angle better than a block or spring lift. Simply vertically relocating the rear end does change the front and rear yoke angles. But, like stated above, the shackle flip uses one attach point, and rotates the entire axle to provide the lift.
I used diy4x's shackle flip kit w/their cross-tied shckles to get a 4" lift in the rear. I don't regret it a bit.
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
