04-23-2012, 08:19 PM | #1 |
14 bolt full float disc conversion
I have a 79 k25 with a 14 bolt full float that is in need of new brakes. I want to do the disc conversion to it but i need a parking brake due to having a 4 speed manual. Anyone done this that can point me in a good direction for this including a parts list id greatly appreciate it. Ps i work for a napa so this helps me a great bit!
Posted via Mobile Device Posted via Mobile Device |
04-23-2012, 10:48 PM | #2 |
Re: 14 bolt full float disc conversion
http://napaonline.com/Catalog/Catalo...(P_RecType%3aA)
herd of guys using these but say they dont really hold as good as you need them to and need to use them everyday or they wont stay ajusted and right i geuss but if you park in gear and set it it should be fine, and as for backing plates http://diy4x.com/cart/index.php?rout...&product_id=35
85 GMC sierra classic : 350, 4spd, 205, 3.42s, 35s |
04-23-2012, 11:02 PM | #3 |
Chevy Enthusiast
I would just use the D44 front calipers and fix up a cable operated disc pinion break, kinda like the old drums that came on a lot of Sm420's in the bigger trucks.
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
04-23-2012, 11:14 PM | #4 |
regular everyday normal guy
check out pirate 4x4, they have some good articles about using the 76-78 caddy calipers that accept e-brake cables
* heres a good link describing the process: http://www.off-road.com/trucks-4x4/r...all-21333.html also heres a link to the "14 bolt bible" very handy page: http://www.pirate4x4.com/tech/billav...ble/index.html
-Andrew- 1987 Chevrolet V10 SM465 NP208 w/ '89 454 dual plane hi-rise 750cfm 1407 w/ '86 10b /14b new motor on the way: GM#990 heads 25cc speed pro pistons COMP XE 274h crane gold rollers Last edited by munice; 04-23-2012 at 11:16 PM. Reason: url didnt work |
04-24-2012, 01:19 AM | #5 |
BAD BOW-Silverado XST
Another 14 bolt disc conversion article.
http://www.shakerbuilt.com/14boltDIY.html |
04-24-2012, 02:39 AM | #6 |
In the Forgotten far North.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
04-24-2012, 11:29 AM | #7 |
Thanks guys i was looking at the cadi calipers but cores are very expensive. Pinion brakes are out of the question. What is everyone using for proportioning valves?
04-24-2012, 11:37 AM | #8 |
Chevy Enthusiast
Here you go then:
04-24-2012, 06:14 PM | #9 |
I am looking into inline tube for a prop valve for my 76 with 1 tons. http://inlinetube.com/Prop%20Valves/VCT104.htm
They dont list the specific part number but mention that they make a disc/disc valve. I already have all stainless brake lines from these guys and have been happy with it so far.
70 stepside 76 blazer 86 Silverado 20 Max Trailering 6.2 Crew 71 Nova SS My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634 |
04-24-2012, 07:05 PM | #10 |
Line locks
04-24-2012, 09:45 PM | #11 |
lol I use a 1' piece of 2x4 for my truck most of the time
-Andrew- 1987 Chevrolet V10 SM465 NP208 w/ '89 454 dual plane hi-rise 750cfm 1407 w/ '86 10b /14b new motor on the way: GM#990 heads 25cc speed pro pistons COMP XE 274h crane gold rollers |
