Old 04-25-2012, 12:42 AM   #1
Widetracker
Re: KYB GR 2 Shocks for Rear Coil Springs?
I'm in the same situation. Did you get an answer from KYB?
Widetracker is offline   Reply With Quote
Old 04-25-2012, 10:31 AM   #2
Regular Guy
Regular Guy's Avatar
Thanks for asking--I blew this off last year and I need to get it done, so I just called KYB tech support.
The guy said their recommended OE replacement for a '70 rear with coil springs is KG5416 Gas-A-Just, because the coils do not support as much weight as a leaf spring set up. The Gas-A-Just has a damping rate close to the original, and is about 10% firmer than the GR-2 (the GR-2 has been renamed "Excel G" and is painted black, but is otherwise the same shock. Just a name and color change). So, a slightly stronger shock is desired.
He said there will not be a difference in ride quality or characteristics if we choose to put Excel G's on the front and Gas-A-Justs on the rear...
Sounds reasonable to me...their tech line is 630-282-5372, FYI.
Regular Guy is offline   Reply With Quote
Old 04-25-2012, 12:08 PM   #3
Widetracker
Mine has helper leafs. I wonder if that makes a difference? I'll call before I place my order if I get a chance. It sounds like the Gas-A-Just are close enough to where the difference in ride will be minimal.
I'd originally looked at running GAJ all the way around since they are the better shock technology, but it seemed the consensus on here was that they were too harsh for a non lowered 2wd. Others commented that they caused problems on the front shock mount after a while.
It sounds like GR2 (EG) on the front and GAJ on the back are the way to go.
