04-24-2012, 12:00 PM | #1 |
The long shaft?
Got the old bed of project chaos this weekend. Couple of things of interest:
1) I am assuming the PO added "overload" springs at some point. They look like addition leaf springs mounted on top of the leafs but dont have spring "eyes" on the ends. They are only connected buy the U-bolt. The ends appear to contact the bottom of the bed when the "normal" springs are fully compressed. Is this correct? 2) There are two separate driveshafts between the transfer case and rear diff, supported by a bearing in the middle. I'm thinking that when I add some lift (4"-6") AND add a ranger splitter (moving the t-case rearwards another 12inches), the pinion angle on the rear shaft is gonna be really high. Why not just run a single large tube from the t-case to the diff? I see large diameter (4 in) shafts on lifted late model trucks all the time. I'm pretty sure they are one piece? Last edited by SunSoaked; 04-24-2012 at 12:13 PM. |
04-24-2012, 08:12 PM | #2 | |
20' Daredevil (Ret)
Re: The long shaft?
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
04-25-2012, 04:40 AM | #3 | |
Collector of Projects
Re: The long shaft?
http://www.highangledriveline.com/ (530) 877-2875 Main shop Phone Number Hours 8am to 5pm for orders Monday thru Friday - Pacific std time Last edited by mcmlxix; 04-25-2012 at 04:43 AM. Reason: added link and info |
04-25-2012, 05:37 AM | #4 |
Re: The long shaft?
I ran a ORD 203/205 doubler and 700r4 in my blazer and it made the rear shaft very short with a high angle. I dropped the t-case mount 2" and ran a telescoping shaft with a cv joint on the t-case side with a flange and made everything 1-ton spicer u joint from Tom Woods in Utah. Quite bullet proof. Put at least 30,000 miles on it joints are still good.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
