#5126 |
Re: What did you do to your truck today?
Maybe not the place to do this, but I posted a request for advice on suspension upgrades, got a few repsonses, would appreciate a greater variety of opinion if you guys wouldn't mind checking out my thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=520865 Thanks, Craiger |
#5127 |
The 60-66 GMC/Pontiac guy....
Pulled the Chevy bedside off my 66 GMC and put a GMC side back on.
Worked on my wifes 63 and my 63 too. Cleaned the work area and put away all the tools. Finally made it to over 100 degrees... summer is a coming.... ![]() I love the heat..
![]() Building Genuine Pontiac Firepowered cars and trucks for several decades. ![]() Why Pontiac?? That's just me daring to be different. ![]() Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac ![]() Last edited by 66-PMD-GMC; 04-23-2012 at 10:00 PM. Reason: spelling |
#5128 |
Got the rest of the front cap off today, and stripped out the interior, now the real work begins. Next stop, suspension upgrades... Calling it a night guys.
#5129 |
![]() Join Date: Jul 2011
Not too much, put some new pedal pads & a new peep mirror.
#5130 |
Your truck with teh blue trip in excellent. The way the rims and trim seems to bring out the Ivory/White (don't tell whihc) really makes it pop.
Damn nice.
http://s1299.photobucket.com/user/jb...23904108567829 |
#5131 |
It's Better With Nitro
I had an old Damplifier Pro kit from Second Skin I bought a long time ago. The new kits have the black foil.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
#5132 |
#5133 |
I agree, I really like the blue because it looks great and its a bit different.
Opportunity usually comes disguised....As hard work!!! ![]() |
#5134 |
Where is Edmore in Michigan? I am going there this summer. Visiting family and taking some parts to my cousin in the U.P.
![]() Building Genuine Pontiac Firepowered cars and trucks for several decades. ![]() Why Pontiac?? That's just me daring to be different. ![]() Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac ![]() |
#5135 |
Sorry meant to send a PM...
![]() Nice truck..
#5136 | |
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
#5137 |
From ready and painted to hours of paint thinner... just because they put the swedish sticker on the wrong primer...
#5138 |
ugh
#5139 |
Picked up a couple of blank keys, and a headlight switch at Antique Chevrolet Parts, looked, and looked, and looked for the clip I have misplaced for the throttle linkage, little dickens is hiding somewhere, will have to fashion a new rod so that I can drill the end, and use washers, and a cotter pin.
Scouring Spaenaur, and McMaster Carr at the moment, any ideas where to find. none of the jobbers, or ACP have this little guy |
#5140 |
Got my rusty chrome American Racing wheels back from powder coat and went over the entire truck with Penetrol to seal the rust and give it a bit of a gloss. No more dusty rust.
#5141 |
I am in the process of reassembling my 64 shortbed fleetside. I fired the 406 SBC last week and it smoked like a coal burner. Engine had been sitting for 3 years. (this truck restoration has been a 20yr process)
So after all of the time and attention to detail. I pulled the engine and tranny back out to disassemble the freshly painted engine and find out why #7 hole is spewing oil. I guess an oil ring is stuck. Really stinks as this engine has 20 min on it!! ![]() I am so close to finishing this thing! Assembly is torture! lol |
#5142 |
Zero Albedo
Vacuumed out the big panel, did some test fitting for the storage benches for the back, flushed the radiator and refilled with new coolant for summer. Installed new temp gauge, installed new gas gauge, hooked up the speedo, pulled the front bumper. It's nice to be back working on the trucks again.
Baz "Deserve's got nothin' to do with it." 66 GMC 1500 wideside longbed 250 4spd "Project Rekker"http://67-72chevytrucks.com/vboard/s...d.php?t=467467 65 GMC 1Ton Panelhttp://67-72chevytrucks.com/vboard/s...32#post4794432 65 Chevy Panel (former U.S.Navy truck) 64 Chevy Suburban Carryall 4x4http://67-72chevytrucks.com/vboard/s...d.php?t=358348 64 GMC 1000 wideside longbed 305 4spdhttp://67-72chevytrucks.com/vboard/s....php?p=3600890(Rip- parts truck now) 68 Dodge Charger |
#5143 |
I worked on the interior last night as well. Trying to get the seat belts fitted and test fit the carpet and door panels etc.
I am thinking about wrapping the door panels in black vinyl? |
#5144 |
I got my bed a little closer to level and adjusted the panhard bar so I can drive higher. Also removed my instrument panel trying to figure out how to do the gauges.
#5145 |
Installed my u-joint, painted the drive shaft and re-intalled. I also filled the holes from the gun rack I removed.
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
#5146 |
Hey Raked 64,
What steering column are you using? |
#5147 |
Busting 46 years of caked up tranny fluid and dirt off the btm of the cab.. fun fun
Build Thread 66 custom cab lwb http://67-72chevytrucks.com/vboard/s...d.php?t=465726 ![]() 66 fleet lwb- In process 64 k10 10inch lift 38.5's- In process 92k1500 400hp on 38.5-parts truck now 8( |
#5148 |
Halfway through a Scotts BBW install (What a great guy to deal with!!!).. Hope to finish it in a couple of days...
My Build CAPRICKUP 1964 Chevy SWB on a 94 Caprice http://67-72chevytrucks.com/vboard/s...d.php?t=492640 |
#5149 |
tore down the front clip of my truck and now i find out that a replacement core support is a necessity!! that is what happens when you start tearing down...!!
#5150 | |
Senior Enthusiast
3/16: http://www.summitracing.com/parts/RNB-118-045/ 5/32” http://www.summitracing.com/parts/RNB-118-005/ Perhaps having a Dorman part number will help you find one clip locally instead of 25 which you'll probably never use. Summit has more listed. They range from 1/8" to 5/16".
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
