house of chevy's
th 400 ?
What would cause tranny fluid to leak from the speedo gear area thanks
1987 m1028 cucv d30 ![]() 2001 chevy s10 2000 honda shadow sabre 1100 "it's going to be an interesting ride home" ![]() |
Re: th 400 ?
O-rings. Remove the speedo housing and you'll find a large diameter o-ring (maybe 2") and if you remove the gear as well, I believe there is a very small o-ring on that too.
house of chevy's
Re: th 400 ?
Ok thank you
Re: th 400 ?
While you have it apart make sure the gear doesn't have any wear where it rides in the housing, also make sure the bore in the housing isn't egg shaped. This normally only happens on the aluminum housings.
___________________ 78 ccsb dually 5.3 4l60e http://67-72chevytrucks.com/vboard/s...d.php?t=491551 |
