Old 04-23-2012, 01:35 PM   #1
robs_c10
robs_c10's Avatar
69 Front End Help
I have 69 C10 that I am currently working on and one thing I need and want to do is the drop spindle and 2" lowering spring. The truck has 6 lug disc brakes in the front already. My question is this. A freind of mine had a complete front end from his 63 that he is willing to give me. I am looking at possibly taking that front end apart (to keep my truck mobil) and cleaning it up and putting the aftermarket parts on it then just doing a quick change out and just add swap the disk brakes to this 63 front end. Is there a huge difference between the two? the only thing I know for difference is the control arm shafts have zirk fittings on the 63 and the 69 has bushings. I just want to know if it will be a headache for me or a relatively easy process to complete this. Thank you for your help in advance.
robs_c10 is offline   Reply With Quote
Old 04-25-2012, 12:00 PM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: 69 Front End Help
may I suggest you read through this great "sticky" that's located in the suspension forum (btw, I've move this suspension too)
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 04-26-2012, 07:33 PM   #3
robs_c10
robs_c10's Avatar
Awesome... I tried to look it up but couldn't find it. Thanks
Old 04-26-2012, 07:49 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
Your '69 didn't come from the factory with 6-lug disc brakes.
Your going to have to find out what spindles, rotors, and calipers are on your truck now.
The only thing I can see you using from the '63 front end is the a-arms.
Everything else is different,... including the balljoints already installed in the '63 a-arms.
Keith
Convert to disc brakes.
Old 04-26-2012, 07:51 PM   #5
lolife99
lolife99's Avatar
Since you said yur '69's current suspension has bushings in the a-arms,... I will assume it has 73-87 parts installed.
Can you get us some pics of your front suspension?
Keith
Old 04-26-2012, 08:41 PM   #6
robs_c10
robs_c10's Avatar
Yeah I can get pictures tomorrow. I basically want the 63 front end just for the A-Arms. The ones on there now are all chopped up. Bumb stops cut off, various hole in them. As long as I go with the old style grease able bushings I can run the a-arms with drop spindles to fit the disk brakes right? I'll send pics like I said tomorrow and maybe that will help. Thanks
Old 04-26-2012, 08:43 PM   #7
lolife99
lolife99's Avatar
You can run the '63 a-arms,... but you will have to install the correct year balljoints.
(73-87?)
Keith
Old 04-26-2012, 08:59 PM   #8
robs_c10
robs_c10's Avatar
Oh ok. I got you.
Old 04-26-2012, 09:01 PM   #9
robs_c10
robs_c10's Avatar
I'll send those pictures just to make sure. Hahaha I appreciate your help.
Old 04-27-2012, 09:23 AM   #10
robs_c10
robs_c10's Avatar
Ok here is the pictures. So I can put those 63 a-arms on this set up and just run a drop spindle from a 73-87 so I can maintain the 6 lug disk brakes right? Thank you.
Old 04-27-2012, 09:52 AM   #11
lolife99
lolife99's Avatar
Yes,... as long as you buy the HD drop spindles fro 73-87 trucks.
(1-1/4" wide rotors)
The 73-87 trucks also had a light duty version. (1" wide rotors)
Got any pics of the 6-lug rotors?
They must be aftermarket.
Keith
Old 04-27-2012, 10:45 AM   #12
robs_c10
robs_c10's Avatar
I knew I should have I will get that this weekend and put it on the board here. Thats some good information to have because these control arms on the truck now are junk.
