#26 |
Re: Are these gaps normal?
Anyone else have any suggestions on how I can fix the misalignment?
I am not sure if I should loosen the cab and shift it around or add shims to radiator support or what. Kinda at a loss so any experienced help would be greatly appreciated. |
#27 |
im guessin that the place to start would be making very sure the cab is on the frame SQUARE. Any misalignment at this point will throw off the rest of the panels as you install them, also maybe elonggate your mounting holes on fenders to allow more movement at the cab to tighten the gap.....just a thought or idea,good luck
#28 |
did you buy new panels an doors?
#29 | |
If this is a completely stupid idea someone please chime in and tell me. Thanks again |
#30 |
I dont see any pics of the vertical gap between the cowl and the front edge of your door, could the cowl be moved forward a little so you can move the hood forward a little to narrow up the gap at the front of your hood and the grill? Does the rear vertical line on the cowl line up with the fender? Am I making any sense at all?
#31 |
When I put my cab on the frame with all new body bushings I had no "play" whatsover in any direction once I put the bolts in.....Actually I had to hammer in the last bolt, so in my case I could not adjust the squareness of the cab at all.....though, I did check the squareness and it was pretty close.....Maybe you will have some "play" in yours..
RM
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288 Last edited by Rack Man; 07-17-2010 at 07:06 PM. |
#32 |
Heymoe, just a thought try loosening the lower rear fender bolt, take the core support bolts out, place a jack under the core support and lift it. The fender/door gap should even up, now tighten the lower rear fender bolt & slowly release the jack that is under the core support. If the gap stays correct then see how much shim you need between the core support & core support mount, add an 1/8 to 3/16 inch to the shim then replace the core support mounting bolts & tighten them down. This problem could be the doors but I would think over the years the front cab mounts collapsed more than the rear cab mounts & stressed (bent)the fenders, or maybe the cab supports rusted out and put even more stress on the fenders. Just guessing. James.
#33 |
[QUOTE=Sport/Truck;3192689]I got my front clip on & everything is real close to perfection. Until I got to the hood! Seems if I pull it forward it closes the gap in the front, but the gap at the cowl is huge! I have the difference split now, does this look normal?
Any suggestions on adjustment that I may have overlooked? s/t QUOTE] Those gaps can be worked down and made uniform. Your core support is too far forward and the fenders look like they need to be shimmed. It took three days but all of the gaps on my truck are 1/4 inch, all the way around. Fit, shim and do it over and over and over till you want to scream. Go slowly and carefully and, if you can, get a friend with more patience than you have to help. That assumes your frame is straight. If it isn't....head for the frame shop! Last edited by Fitz; 07-18-2010 at 11:20 AM. |
#34 |
![]() Join Date: Apr 2009
yep me too would like to see how in depth this one gets.. seeing i will be out of town till December
#35 |
yesterday i went to a car show and saw to 1972 chevy trucks one was completely redone top to bottom and one was never touched, the one that was never touched looked perfect but the one that was redone had huge gaps and what the guy did was fix the gaps on the diver side(so it wasnt a eye swore to him)an left close to a 1inch gap on the passanger side hood so its just how it is when you take these trucks apart, sometimes they turn out great, sometimes you have some gaps.
#36 |
have you tried shimming the radiator support up
#37 |
#38 |
Just a guess but is it because you are using the 67/68 hood and the 69-72 grill moulding that might be throwing the hood off?
Just would like the snow to stop so I can actually work on my truck!!!!!!!!!!! |
#39 |
Yes it is the re pop doors. bought a pair and for me anyway they didn't fit for shizz took them back & got some doors off a dump truck! and my problems went away this is just my opinion. try good used doors its worth the work sorry, repops are not for me best of luck, Pat
#40 |
as far as the gaps, GM plus or minus .25 and its perfect! remember our trucks were used as trucks so the gaps in your photos are the way they left the line in most cases . maybe try and move the hood&valance toward the grille. just trying to help. work at it and I'm sure you will get it to line up. cheers, Pat
#41 |
There is only so much you can do with mismatched sheetmetal. These were work and farm trucks after all!
If you are trying to get perfect body line alignment Then you will have to make up for the sheet-metal with bodywork. I got this method from a body-man: 1. Once you get body, doors and fenders mounted close as possible put a piece of masking tape in the cracks set back just a hair. 2. Use short fiberglass putty and putty right over the door gap so the door and body are perfectly even. Use a very wide putty knife to get the putty line totally flat. I use an 8" plaster knife. In some cases I used a 36" painting mask bar (plastic with a metal edge). 3. Once you get fiberglass real close to perfect, cut the door gap open with a cut-off tool, open door and remove the masking tape. 4. Finish up with fine putty work. Use a long sanding block to get it all mirror flat, sanding by holding long block horizontally and pulling up/down in opposing 45 degree strokes.
72 Fleet (died) 78 Step (sold) 55 Step named Fred (sold) 00 F150 68 Step (named El Scorcho by PO) Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932 |
#42 | |
Matching the gaps by reshaping the panels is the prefered way.....but plastic filler is not the best method. It is not very strong and will likely break off at some point.
I prefer to cut the panel itself and push it closer to close the gap. Then weld it back. Of course this has to be done before body work and paint...but then so does the bondo route. With painted parts you are pretty much stuck with shimming/adjusting.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
#43 |
did you end up shimming your radiator support at all if so how much
#44 |
#45 |
Sierra Grande Club
The only gap I see is the date this was originally posted.
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
#46 |
am i just retarted or are the 67 68 chevy and GMC trucks eaier to line up the hood to the cowl and end of fenders? it seems to me that all 69 72 chevy and GMC trucks all have theses gaps... it seems that since the grille comes up to the hood its another area to gap and it makes it harder....
#47 |
Not only these trucks,but cars too were never built to the standards people expect now. Yes,you can do whatever it takes to get better gaps and alignment and have a vehicle that looks better than new. It's hard to do without body work to get perfect and I choose no body work and just don't look as hard at my trucks. I don't show them anyway. But,when I did,I won some trophies without worrying about all that.
