Old 04-29-2012, 12:04 AM   #51
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Re: 1978 CC Dually I picked up the other day
Thanks. One way or another its getting a cast iron gear driven T-case weather it be a married np205, divorced np205, np202, atlas, rockwell or other.
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 04-29-2012, 09:33 AM   #52
USSkoval
Originally Posted by 1985-GMC View Post
Definitely 4" or under, I still want to be able to pull a gooseneck with it. I'll get the cummins as high and far back as possible even if I have to cut into the firewall and trans hump. I think im going to put 37" hummer tires on it too, and I might know a guy with some 16.5 dually wheels I can get. This also means taking out about a 1.5" wedges out of the front of the front fenders and 2"s out of the rear of the front fenders for extra tire clearance while keeping the stock "appearance".
You shouldn't have to trim very much, if at all. I run a 4 inch lift on mine with 36 inch tall tires and there is zero trimming done. I think the most you would need to do is trim the lower edge behind the tire, that little "corner" that tucks under.
Originally Posted by Lower View Post
I have seen plenty of overly abused 241's in offroad rigs live a long time. If you can find a shop to do it you can flip the 241 over and run it upside down so its a right side out for the front. Just need to tig up a couple holes so it wont leak.
Looks like you found a nicely documented truck to start with. I look forward to seeing how it turns out.
Why can't the passenger drop 241 be used? Is it because a Dodge nv4500 is being used, rather than a GM?
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'79 K30 Crew Cab Dually
'84 C10 Short Stepside
'88 K20 Suburban
USSkoval is offline   Reply With Quote
Old 04-29-2012, 07:59 PM   #53
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
I guess i'll see how much room I have when I get to that point then decide from there but I want plenty of tire clearance. Ive done some measuring on my gmc with the 4" lift and it looks like that's what im going to need to do to run 37"s.
Im not sure but it probably could be if you swapped in the 29 spline input instead of the 27 or 32.
Tony
Old 04-29-2012, 08:16 PM   #54
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Ok I got the spacer done and on the truck, it keeps the carb MUCH cooler. I coated the spacer in Plasti-dip spray. It idles and runs much better, now ive just gotta replace the clutch...
Tony
Old 04-29-2012, 09:28 PM   #55
v30crewcab
v30crewcab's Avatar
the cummins is a tight fit, but theres no need to cut up the firewall. I have a 4" lift, 35's, and tow with mine all the time. 37's should fit fine.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 04-29-2012, 11:06 PM   #56
Your41Plague12
Your41Plague12's Avatar
My dad had a 4" lift and 37x14.50 Armstrong Tru-Tracs on a 78 K10 back in the day. As already stated, he had to trim a tiny portion of the back corner of his front fender. It looked really mean with that little lift and that much tire.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 04-30-2012, 09:08 AM   #57
Mattman2010
Mattman2010's Avatar
Looking good tony!
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
