carb linkage
Hi Guys
Heres my problem I have a 1970 C/10 with a small block V/8 in it with a turbo 350 trans. The trouble is it sets in the 6 cylinder location(the motors up againts the fire wall.) The carb linkage is for a 6. I don't have enough throw to open the 4brl.I know I can put a cable in but I don't think it will help It'll still be too long. Cutting the cable just seems like guess work.Anyone got the same problem? Thanks Buz48 |
Re: carb linkage
Wouldn't it be better to take the time and position the motor correctly? That way things like, linkage, exhaust and cooling fan operation are all stock replacment items.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Re: carb linkage
HI Tim
Unfortunately this is the way I bought this I could tell you horror storys about how this was put together ,drive shaft that was cut and welded back together,motor mounts with no bolts in them.Are just a few.I would like to find the guy who put this together and punch him in the nose Buz48 |
Re: carb linkage
I'm sure you don't want to hear this but fixing the problem is going to make life easier in the long run. Maybe start with a CL or better a board sourced drive shaft. Then start moving things around. If you need frame stands/mounts they should be real easy to find on the board as well. If it is a matter of measurements they are likely free for the asking. Downtime is probably the only real problem.
Chemist under the hood...
Re: carb linkage
I had the same problem. My original carb had the right bracket that attached to the linkage but I bought a re-built carb and had to fab something to work with the linkage (after some adjusting, it works fine). Here's a pic.
Current fleet: 2013 GMC Sierra, 5.3L, 4x4 1988 GMC Sierra, 305, Auto 1984 Jeep Grand Wagoneer, 360 V8 1997 VW Cabrio, 2.0L 2017 Toyota Rav4, 2.5L Stuff I wish I still had: 2013 Toyota Matrix [RIP] 1967 GMC 910 Fleetside, 283 V8 [1st Love-SOLD] 1987 Jeep Cherokee Laredo 4X4, 4.0 I-6 [SOLD} 1994 Chevrolet Caprice Classic, 5.7LV8 [SOLD] 1995 Chevrolet Astro AWD, 4.3L V6 (RIP) 1998 Chevrolet Suburban 4x4, 5.7L V8 [SOLD] |
Re: carb linkage
Here is a link to exactly what I did when I swapped out my 402 with the factory Quadrasuck for my 454 with a holley. It worked great, and looks awesome too.
http://www.fordmuscle.com/archives/2...kage/index.php |
Re: carb linkage
Thats just what I was looking for
Thanks Buz48 |
Re: carb linkage
#9 | |||
"I ain't nobody, dork."
Re: carb linkage
Gary
