Old 05-01-2012, 01:00 PM   #1
2003 silverado
2003 silverado's Avatar
Blazer Speaker mounting problems
Ok I just got a under dash speaker .The problem is the mounting holes interfer with the A/C controller .what do I do????????????
!972 K5 Blazer,Highlander,A/C a twin to the one I Had
1972 K/5 Blazer CST Highlander 15YR project
2003 Silverado Crew 2500HD (Daily driver)
1997 Ford focus (Beater)
2003 ford Taurus (student)
2014 Ford Fusion HYB (wife)
2003 Jetta ( Student)
2003 silverado is offline   Reply With Quote
Old 05-01-2012, 01:03 PM   #2
jaros44sr
jaros44sr's Avatar
Re: Blazer Speaker mounting problems
Dont you just take out the two screws that mount your control panel, and remount the speaker bracket using the same two screws. Dont have ac, but that is the way it works with the heater control panel
Got pics?
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 05-01-2012, 01:18 PM   #3
2003 silverado
The ac controller has mounting brackets that get in the way also here is some tidbit of Info
Blazer and Jimmy Speakers
One of the most unusual features of the 1967-1972 series of trucks is the unique placement of the 1969-1972 Chevrolet Blazer and GMC Jimmy radio speaker. Unlike the pickup, Suburban, and large trucks; the radio speaker is not under the top of the dash. In fact, the dash does not even have grille slots to allow sound to come from a speaker.
Because of the Blazer and Jimmy's removable top, GM knew that some would occasionally be caught in the rain. This would quickly ruin a speaker that was in the traditional location. Thus, on the 1969-1972 Blazer and Jimmy only, the factory radio speaker is in the right side interior quarter upholstery panel behind the front seat. If the vehicle did not come with interior rear panels, the speaker was out of sight at the bottom edge of the dash.
Old 05-01-2012, 01:22 PM   #4
2003 silverado
I guess now I need to cut into the panel????????? and find a pic of that to see what it looks like???????
Old 05-01-2012, 09:37 PM   #5
pound41
i had a 72 with ac and it had the speaker bolted with the ac controller dont have that truck any more so i cannot help with details
pound41 is offline   Reply With Quote
Old 05-01-2012, 09:48 PM   #6
1972_K5
1972_K5's Avatar
My blazer came with the speaker mounted in the dash. It is non AC though.
1972 K5 CST
1972_K5 is offline   Reply With Quote
Old 05-01-2012, 10:17 PM   #7
rsavage
rsavage's Avatar
I have AC and the speaker bolted up under the dash but on the outside. I assume that is how it was supposed to install as I couldn't get it to work inbetween the dash and AC/heat control.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 05-01-2012, 10:49 PM   #8
1949gmc
Here's where the General mounted the one in my '71.
1949gmc is offline   Reply With Quote
Old 05-01-2012, 11:41 PM   #9
Dmcinfo
2003 or rsavage
Where did you get the under dash speaker and (for rsavage) how does it sound?
Dmcinfo is offline   Reply With Quote
Old 05-02-2012, 02:45 AM   #10
old man jimmy
I ordered mine with A/C and AM, and that's the way they mounted them in St. Louis. (where it was assembled) In the 72's anyway.
old man jimmy is offline   Reply With Quote
Old 05-02-2012, 06:25 AM   #11
2003 silverado
I tryed it between the ac-dash would not work.......tryed to mount the way everyone is talking about ,BUT the bracket on the speaker is treaded and are not as flat as rsavage
Old 05-02-2012, 06:30 AM   #12
rsavage
rsavage's Avatar
Dmcinfo,
I bought it off the board. They come along once in a blue moon. As for sound, I couldn't tell you as it isn't working. I will probably have to send it for repair. I am almost positive the radio is good but I am loathe to get into it right now. Removing a radio in an ac truck is a pain so before I pull it out I am going to make sure that it is the speaker that isn't functioning. Probably a next winter project as I want to drive the Blazer now.
1961 C1 Corvette
2021 Durango RT 5.7
Old 05-02-2012, 06:40 AM   #13
2003 silverado
I just picked mine up from a member- oldschool it doesnt work but thats fine, I went for the look
Old 05-02-2012, 09:08 AM   #14
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
[QUOTE=
....Thus, on the 1969-1972 Blazer and Jimmy only, the factory radio speaker is in the right side interior quarter upholstery panel behind the front seat. If the vehicle did not come with interior rear panels, the speaker was out of sight at the bottom edge of the dash.[/QUOTE]
I assume this is a quote from some litereature? My Cheyanne package Jimmy didnt have any speaker in the rear upholstery panel. I dont think Ive ever seen a 'factory' speaker there... anyone else seen one??
Tom Vogel is offline   Reply With Quote
Old 05-02-2012, 10:56 AM   #15
2003 silverado
heres a link I found this
http://www.oldchevytrucks.com/blog/i...hp/tag/blazer/
Old 05-02-2012, 03:21 PM   #16
1949gmc
I was hoping that old man jimmy would chime in here.... I knew he would be the guy to ask!
Old 05-02-2012, 04:07 PM   #17
47thriftmaster
47thriftmaster's Avatar
My 72 CST Blazer with AM/FM radio had and still has (have not taken it out yet) the original speaker under the dash w/speaker holes in the dash. In the picture it is in the upper left corner, picture is from the glove box as I was pulling the A/C.
Looked but I don't have a pic of the top of the dash.
47thriftmaster is offline   Reply With Quote
Old 05-02-2012, 06:03 PM   #18
rsavage
rsavage's Avatar
If the speaker was placed in the right side panel on trucks with side panels then the survivors with radios would have holes in them. I have a set of originals I bought from a board member and the right side doesn't have a speaker hole. I haven't seen a speaker installed in that way from the factory. I don't think that the blog post can be counted upon as reliable. It refers to the Blazer as having a 107" wheelbase when the diagram below shows the correct 104". Further, it appears that the brackets on the speaker shown have been bent to 90 degrees?
1961 C1 Corvette
2021 Durango RT 5.7
Old 05-02-2012, 07:05 PM   #19
2003 silverado
Ok back to the org problem and I guess I should have posted pics. I think maybe the brackets are wrong????? they are threaded
Old 05-02-2012, 07:08 PM   #20
jaros44sr
jaros44sr's Avatar
Dont think they should be threaded, got pics of the bracket?
SAFETY FIRST
AS usual, off topic
Jim
Old 05-02-2012, 07:10 PM   #21
jaros44sr
jaros44sr's Avatar
Man that was quick
That nut shouldnt be welded on there, dont know what application it would be for.....
Maybe dual speakers, across the lower dash
SAFETY FIRST
AS usual, off topic
Jim
Old 05-02-2012, 07:44 PM   #22
rsavage
rsavage's Avatar
I believe mine were threaded also (had nuts welded on them). I ground them off and redrilled so AC/heat control screws would go through. Any of the photos I found had it in the center, but perhaps the correct install is as 1949GMC pictures as the threaded nuts would be used. I am going to check my assembly and chassis manuals to see if I can come up with a GM picture.
1961 C1 Corvette
2021 Durango RT 5.7
Old 05-02-2012, 07:58 PM   #23
71RestoRod
71RestoRod's Avatar
Attachment 917960
Same place I have my stock speaker mounted. Those welded nuts would come in handy in this location as I believe there are only holes in the dash lip.
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod
71RestoRod is offline   Reply With Quote
Old 05-02-2012, 09:34 PM   #24
oldschool18
oldschool18's Avatar
didnt you get any instructions when you bought that speaker
_________________________________
62 Impala
70 C-10 LWB
71 K-10 SWB
85 C-10 LWB==SOLD
01 2500 HD
Members Met......2003Silverado (Dave)
oldschool18 is offline   Reply With Quote
Old 05-02-2012, 09:42 PM   #25
1949gmc
Brackets aren't wrong... that's how it's supposed to be.
