Old 05-01-2012, 08:23 PM   #1
Matt Cramer
Installing 3 point seat belts in a 1972 C10
So, I have a '72 C10 with lap belts, and want to put 3 point seat belts in there. I'm going to try using a cheap retractable set since I have non-retractable ones in a Dodge Dart and it would be a nuisance to adjust this each time we change drivers. My wife has to drive this one too.
I ordered a set of these from Summit last night:
http://www.summitracing.com/parts/HFM-SB3PRTN/
And they got here this afternoon. The fact that I'm about 15 miles from their warehouse helps. But still, good job on their part.
Anyway, I'll be putting them in sometime this week. Any particular tips about this? It looks like it will be pretty easy. There's some sort of point on the roof pillar that looks like it would work and I'll use it unless somebody has a warning that it's not sturdy enough to sue. There's a cap in the fitting that I'm not sure if there are any tricks to removing it, such as slotting it with a Dremel or if it just pops out if you pry on it. If anyone has any tips, gotchas, or anything else to say on this, please let me know!
I'll be posting pictures of the install once I get to work on it.
Matt Cramer is offline   Reply With Quote
Old 05-01-2012, 08:30 PM   #2
Ironhorse
Ironhorse's Avatar
Re: Installing 3 point seat belts in a 1972 C10
Matt, the point you are referring to on the cab wall is an actual factory mounting point for the optional 3 point seat belts from back in the day. Not a lot of people purchased the 3 point belts making them rather a hard to come by option. When you consider trying to match the interior color of your truck it would be even harder. The small plastic cap is just a snug fit, use a small slot screw driver or a pick to remove the cap. Be sure to place the caps in a small container so you don't mis-place them if you decide to remove the belts as I don't think the caps are re-poped. Not sure what the thread size is in the hole. Hope that helps and welcome to the best truck board on the web.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Last edited by Ironhorse; 05-01-2012 at 08:31 PM. Reason: Can't spell sometimes, LOL !
Ironhorse is offline   Reply With Quote
Old 05-01-2012, 08:37 PM   #3
68gmsee
Active Member
68gmsee's Avatar
That plastic piece hides a bolt hole. I believe it was made for shoulder belts and I seen pictures of some of the guys here using it for their three point harness. I would just gently try to pry it off if you can do it without damaging the paint. I don't like to damage anything that I may want to use at some later date from these trucks.
68gmsee is offline   Reply With Quote
Old 05-01-2012, 08:39 PM   #4
68gmsee
Active Member
68gmsee's Avatar
Yeah, forgot to welcome you to the site...
Looks like Ironhorse beat me at typing.
Old 05-01-2012, 08:55 PM   #5
Matt Cramer
Thanks guys! Seems like this will be a pretty easy mod!
Old 05-01-2012, 09:12 PM   #6
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
I'm going to do this to my truck some day too. Welcome to the board!
Ryan
1969 Chevy milk truck
Old 05-01-2012, 09:47 PM   #7
Hubscrub
Cruzin
Hubscrub's Avatar
i installed some in my wife's truck only advice i have it i used some grease on the bolt to help it go through 40 years of crap plus the previous owners paint jobs, mine were alittle tough to get going before the grease i didn't want to screw up threads/bolt stuck, that would have been a pita!
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 05-01-2012, 09:48 PM   #8
Cruisin' Oklahoma
Cruisin' Oklahoma's Avatar
Matt,
Welcome to the board! This was one of the first things I did to my truck 2 years ago since it had no seatbelts when I got it. Everybody is correct about the top plug. If I Were you, I'd pull the seat out (unless it has buckets). I didn't and it was honestly just unhandy getting to my bolts behind the seats. If you have any other questions feel,free to ask as everyone on the board is very helpful!
69' Stepside, 350SB/TH350, Holley 600 4 Barrel, Headers, Edelbrock Intake, Valve Covers, and Breather, 275/60 R15's, Disc Brake conversion.
"For we know that God works all things for the good of those that love Him, to those that are called according to His purpose." --Romans 8:28
Cruisin' Oklahoma is offline   Reply With Quote
Old 05-01-2012, 09:54 PM   #9
hounddogs!
Restoring it $200 at a time...
hounddogs!'s Avatar
Welcome! I'm pretty sure the upper factory anchor is a 7/16-14 thread. The plug that you see is just barbed plastic-it's not threaded into the nut.
I had to use a piece of angle iron running parallel to the seat rail, but that was to mount the retractor from a Delta 88. The inside pieces all used the factory mounts on the floor.
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society
'68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327.
DD '09 Pilot
Weekender '65 Skylark 300-4V-4 speed
Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine.
Son's '04 F250 SuperCab 6.0
hounddogs! is offline   Reply With Quote
Old 05-02-2012, 12:13 AM   #10
swammie911
I did this to mine, really easy. The only slightly tricky part is clearance for the drivers side. If the tank is still in, it's pretty tight fit for the belt recoil mechanism. I was able to make it work quite easily with a slight bend in the bracket. Passenger side was a piece of cake!
It will be fun to watch your passengers try to figure out how to pull the belts slow enough so they don't lock up....!!
swammie911 is offline   Reply With Quote
Old 05-02-2012, 07:03 PM   #11
fasttech
fasttech's Avatar
Welcome Matt! I did this a few years ago since I didn't have any seat belts and it wouldn't pass inspection. lol Any way I bucket seats so I ordered a universal set from one of the vendors who has ads in Classic Truck mag. They have the plastic holder that keeps the buckle straight up in place. I used a tap to clear out the holes in the sides of the cab. Can't remembe the size off hand. I used some 2X2 1/8" angle iron to fab up brackets for the bottom. Looks almost factory. If you are using OEM 3-point belts it should be a snap.
fasttech is offline   Reply With Quote
Old 05-04-2012, 09:19 PM   #12
Mufrat62
I have been thinking about the going to the 3 point belts as well. However on my cab( small rear window) so likely a 1967 cab there are holes there but they are not threaded- just a hole. Is this different than what you guys are speaking about or has anyone seen this as well???
Mufrat62 is offline   Reply With Quote
Old 05-05-2012, 12:46 AM   #13
kevmcrae
kevmcrae's Avatar
type this in the search bar "aftermarket 3 point seatbelts" for more info and pictures
kevmcrae is offline   Reply With Quote
Old 05-05-2012, 11:28 AM   #14
fasttech
fasttech's Avatar
Mufrat62, I have a 67 GMC with a small rear window like yours. My holes were treaded but had the plastic covers over them. I just had to pop of the caps and chase them with a tap to clean out the threads. I have bucket seats so I purchased a set of belts from AutoLoc. See attached picture.
Old 05-05-2012, 02:09 PM   #15
leddzepp
Moderator
leddzepp's Avatar
The pillar mount takes a 7/16" 20 bolt (fine thread)....unlike the floor mounts which use a coarse bolt.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 05-06-2012, 07:51 AM   #16
Steve Hafner
Steve Hafner's Avatar
I didn't do the work when mine were installed, but it was an easy, bolt-in process.
Life is short . . . we only have, right now.
My 70 C-10's BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=475526
Steve Hafner is offline   Reply With Quote
Old 05-06-2012, 08:32 AM   #17
jjzepplin
jjzepplin's Avatar
That's one nice interior Steve! Say, what's that second knob to the left under your light switch?
jjzepplin is offline   Reply With Quote
Old 05-06-2012, 09:09 AM   #18
Steve Hafner
It's for the manual throttle
Old 05-06-2012, 02:21 PM   #19
Matt Cramer
Got the belts in, but not 100% happy with the install - the buckles are just barely peeking out of the seat. I need to fab up something to extend the buckle side. Using the same belt setup fasttech posted, but with a bench seat.
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Old 05-07-2012, 08:45 AM   #20
jjzepplin
jjzepplin's Avatar
Looked at my truck and it does not have the hole mentioned. It's a 1970 though. Could I just slip a bolt back there and weld it up?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
Old 03-05-2016, 04:13 AM   #21
gijoecarlos
Does someone have pictures on how these belts are mounted on the floor? do i need to drill an additional hole or do they bolt onto one hole only? Thanks in advance!
gijoecarlos is offline   Reply With Quote
Old 03-05-2016, 10:02 AM   #22
You need to spend more money to get a quality set. Morris makes nice sets with (newer) upgrade GM buckles.
http://www.speedwaymotors.com/Morris...kup,79315.html
Old 03-05-2016, 09:20 PM   #23
89AKurt
89AKurt's Avatar
I was wondering...... bookmarked.
1968 Long Bed
2016 Honda Civic Coupe EX-T ticket magnet
89AKurt is offline   Reply With Quote
Old 03-06-2016, 01:13 PM   #24
kevmcrae
kevmcrae's Avatar
I got mine here
http://www.seatbeltsplus.com/product/CHT6872-Bench.html
for $239
Old 03-06-2016, 10:47 PM   #25
I just knew Speedway sold the Morris belts cuz I've seen them at rod runs and wanted to show an example. He can do his own shopping. I have later OEM Suburban belts that I paid $50 for
