Distributor - which one?
My '70 402 had an HEI when I bought it, but I am restoring it to stock-appearing. As much as I want a factory-appearing setup, I'm not ready to live with points.
I like what I've read about the new Igniter III module (rev-limiter, multiple spark, etc, without a box). But I really don't want one of their chromed-out billet distributors. Problem is, right now I don't have a stock distributor to convert. And I'm worried if I grab a junkyard unit I'm asking for trouble. So I'm wondering what I should do... grab an O'Reily auto parts remanufactured unit and then install an Igniter III module? Put another way, what's my shortest and cheapest path to a factory-appearing small cap distributor with a modern module (like the Igniter III?) Thanks! Dave
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
Junior Member
Re: Distributor - which one?
I'd get this and throw electronics in it. If it needs new bushing(s) or whatever so be it.
http://www.ebay.com/itm/1971-CHEVY-C...91d88d&vxp=mtr
"I was patina when patina wasn't cool." 1973 Cheyenne SWB Sunset Gold / Frost White / Saddle |
![]() Join Date: Oct 2009
Pertronix does offer some pretty stock looking dizzies - but you're correct, the base is normally billet. If that's the only reason you don't want the Pertronix unit (i.e. you really DO want it except for its billet-ness), you could squirt a quick shot of satin silver (some eastwood metallic finish stuff would be great) on the exposed parts. Should not see much wear and would look stock.
However, I like the second approach - OReily's (simply to have a stock, sound, dostro to start with) and then add pertronix. Least expensive approach is to go grab pretty much any distro off a junkyard small block and you're good to go. Rebuild it with a new rotor, toss the points plate, install the pertronix stuff, call it a day. (as stomper points out - excellent option) Btw, there are a few threads on here where folks "dis" (no pun intended) the pertronix stuff, might be worth a search before you make up your mind. I don't mind points, but my truck isn't a DD. The last 72 I had was a stock ignition, and it was my DD - seemed I was re-setting the points all the time. So on a DD, I would do the Oreily's (or any store like it) route + pertronix, or the junkyard route + pertronix. One thing I prefer to do is this: Install the distro with points FIRST and get it running, THEN go back in and add the pertronix. Can help ID any basic distributor problems the distro may have before you install the pertronix unit - and thus help eliminate confusion after you add the pertronix stuff and all of a sudden nothing is working... If you two-step it, you'll know you may have gacked up the pertronix install and eliminated the possibly it's the basic distributor (or wiring, etc). My 2 cents. I'm like you though - I like the stock look, HEIs look very out of place in an old engine compartment, but I also like an electronic ignition on a DD. So, that narrows down the options real quickly. If you consider cost as important - someone on here most certainly has a distro on one of the whole-truck-parting-outs on the parts for sale section. Might be worth a try at the dirt cheap route before shelling money out for OReily or a full Pertronix distrib. |
Dave, I'm glad you brought this question up. I will soon be rebuilding a motor for my ride, a 327. I want it to be factory/ stock appearing also. I had been wondering about the distributor also. Although, I do love my HEI and disk breaks.
Good luck! Keith |
I used to run a Pertronix on a Dodge Dart, and didn't have any trouble with it. I'd probably trust the Pertronix a bit more than a typical parts store rebuilt part, although my main worry with distributors is the advance curve is probably something random. Overall, I don't think it's a bad plan. Although starting with a distributor from the parts for sale section may be as good a starting point or better.
I found and bought their new "Cast, Stock Look" unit for Chevy SB/BB. It claims to be molded after the original Delco distributors.
Found it about 10 minutes after finally asking here, which tends to be the way things work :-) http://www.pertronix.com/prod/new/details.aspx?ID=143 I ordered the D7105600 that has the Igniter III module. It's supposedly multispark all through the RPM range, has an adjustable electronic rev limiter, and an adjustable vacuum advance cannister. No idea how the advance curve compares to the stock distributor, but my shop still has a distributor machine (not many do these days!). It'll be a while before the engine hits the dyno, but I'll try to report back with my impressions once I get it running.
Cool! They should have made it that way in the first place! Us truck folks aren't all about bling!
Dave, the cheapest thing to do would be to box up your HEI and ship it to me and I'll box up all my points stuff and send it to you! With an extra set of new points.
-Scott- |
#9 | |
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
Who's got steelies?
![]() Join Date: Feb 2006
Go with Dave:
http://www.davessmallbodyheis.com/ Installed one of his conversions just a couple weekends ago now. Stock look. HEI performance. No Points. I'm very happy. Expect him to take about a month, but very worth it.
![]() ![]() ![]() ![]() ![]() ![]() How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
thanks for that link oldgold - good gouge.
