Old 05-01-2012, 05:19 PM   #1
TheApocalyptican
TheApocalyptican's Avatar
Engine Bogging
I have a problem with bogging from idle to about 2000 rpms. The bog is still there above 2000, just a whole lot less noticeable. It doesn't start happening until the truck is warmed up. Once warmed up, the problem comes and goes.
This is on a 350TBI/ 700R4. I have completely gone thru the TBI/Fuel system and had a computer hooked to it. Everything in the TBI system is working as it should, and reading on the computer as it should.
So, this leads me out of the TBI system to look for the problem, which is where you guys come in. What could cause an intermittent bogging issue on a warm engine?
1995 Suburban K2500 454.....off road & towing
1999 Astro, work van
2006 Silverado 2wd 5.3 w/4.5" lift and 33s
TheApocalyptican is offline   Reply With Quote
Old 05-02-2012, 12:36 AM   #2
wyattglock
wyattglock's Avatar
Re: Engine Bogging
What type of distributor are you running? I just went through a similar problem with my 454tbi, turns out the pile of crap aftermarket dizzy I wasted my money on was the problem. I changed back to an AC Delco unit and put in a new module and the problem went away.
wyattglock is offline   Reply With Quote
Old 05-02-2012, 12:46 AM   #3
TheApocalyptican
Re: Engine Bogging
To be honest....I'm not sure of the brand, I'll have to look. Didn't really pay attention when I had it out to do the intake manifold, as I needed to get the truck back together asap. I've kinda been leaning toward a dist problem, as it seems to me that the problem feels like the timing being retarded. But the ecm itself is calling for the correct timing, so that leaves the dist. What aftermarket brand were you using?
Old 05-02-2012, 12:50 AM   #4
wyattglock
wyattglock's Avatar
Re: Engine Bogging
I dont recall the name, but it was a "special" one on fleabay that looks exactly like the Summit brand with the red cap. Has a nice billet base, but the reluctor isn't machined correctly for the pickup to sit around. Ends up hitting the pickup and causing signal problems to the ecm.
I am running an MSD Streetfire coil. I figure a little more juice for spark isn't going to hurt. In addition I am running Jegs 8mm wires and Accel header plugs. This seems to be the best combo for my engine.
Old 05-02-2012, 01:26 AM   #5
butch86
butch86's Avatar
Re: Engine Bogging
listen did you put an aluminum intake on your motor?????? if so try putting a ground wire to the hold down nut/bolt for the distrib. this has fixed a simular problem for me in the past. now i run a ground wire/ strap to every dizzy hold down bracket nut/screw.
most people sleep peacfully at night because, rough men stand ready to do violenceon there behalf.
butch86 is offline   Reply With Quote
Old 05-02-2012, 01:54 PM   #6
TheApocalyptican
Re: Engine Bogging
Yea, it's a stock manifold, but it is aluminum. I've got plenty of wire, so I'll give this a try.
