Old 05-02-2012, 07:56 PM   #1
88Jimmy4x4
88Jimmy4x4's Avatar
is my 1976 small or big hump for carpet replacement?
Need to order carpet, all the catalogs say floor shift manual trans and 4x4 are big hump and 2wd auto are small hump. However I have heard all bolt in humps are big....Im confused because I clearly have a bolt in hump and cutout for standard trans if needed.
1976 GMC Sierra C15 2wd TH350 trans with 350 VIN L engine
Is there another way to tell?
Heres a view looking from underneath my truck
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 05-02-2012, 08:03 PM   #2
J Knight
J Knight's Avatar
Re: is my 1976 small or big hump for carpet replacement?
JB, it looks like your truck was originally a 4spd granny. I think thats a high hump.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 05-02-2012, 08:04 PM   #3
88Jimmy4x4
88Jimmy4x4's Avatar
anything is possible, but theres no indication of a clutch pedal or any linkage anywhere
1991 GMC Jimmy 4x4
Old 05-02-2012, 08:16 PM   #4
J Knight
J Knight's Avatar
The hump looks totally factory but the patch that is rivited in doesnt.
John
Old 05-02-2012, 08:20 PM   #5
88Jimmy4x4
88Jimmy4x4's Avatar
still confused
1991 GMC Jimmy 4x4
Old 05-02-2012, 08:30 PM   #6
donut
donut's Avatar
My guess would be high hump because it's bolted in. It's only a guess though.
Look here, http://forum.73-87chevytrucks.com/sm...c,11838.0.html
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 05-02-2012, 08:38 PM   #7
J Knight
J Knight's Avatar
LMC shows two carpet options, a 2wd low hump, and a 2wd/4spd or 4wd high hump. My guess is also high hump.
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=121
John
Old 05-02-2012, 08:54 PM   #8
76stepsidechevy
looks like a high hump, can you get a pic from the inside?
76stepsidechevy is offline   Reply With Quote
Old 05-02-2012, 09:27 PM   #9
88Jimmy4x4
88Jimmy4x4's Avatar
Thanks, but the pics arent working
I think it may be high, previous owner replaced carpet and it never fit correctly, like it was stretched away from hump and didnt contour floor.
Im gonna remove carpet/seat this weekend and take an inside pic
1991 GMC Jimmy 4x4
Old 05-03-2012, 06:15 AM   #10
donut
donut's Avatar
Pics worked for me (even on dial-up) and they're in his tech section so they're pretty much locked down. You may have to wait for them to load though.
When you post up a pic of yours, someone will help identify exactly what you have.
Old 05-03-2012, 07:06 AM   #11
xrcr
This is a pic from a 76 3/4 2wd manual. I called this high hump. Not sure if this helps....
xrcr is offline   Reply With Quote
Old 05-03-2012, 10:50 AM   #12
Keith Seymore
Keith Seymore's Avatar
2wd auto/ 2wd manual column shifted = low hump
2wd manual floor shifted (both M20 and My6); and 4wd = high hump
As others have said - looks like you've had some floor shifted manual action at some point in the past.
What makes you think the truck was originally a TH350? Because that's what's in it now? Any other indications (brackets and such) that would indicate it was originally a manual trans?
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 05-05-2012, 02:28 PM   #13
88Jimmy4x4
88Jimmy4x4's Avatar
K
well guys looks like my truck was a 4 speed manual trans from factory and got switched to auto at one time.
this the big hump right?
does this look like yours Keith?.....whats this cover plate near brake on firewall?
so this is large hump right?
1991 GMC Jimmy 4x4
Old 05-05-2012, 03:28 PM   #14
donut
donut's Avatar
Looks to me like a 2wd high hump, same as pic xrcr posted.
Hole in the floor, clutch? Kinda looks like it as the patch jobs look similar, or at least done at the same time.
Old 05-05-2012, 03:36 PM   #15
Keith Seymore
I agree, looks like a 2wd high hump.
I neglected to take any pictures of my bare floor; it's a 2wd high hump (because of the MY6) but not a bolt in.
K
1979-1986
1986 - 2019
Old 05-05-2012, 04:27 PM   #16
88Jimmy4x4
88Jimmy4x4's Avatar
yes that helps, its just like mine even same color
Thanks for the help everyone
Keith.....what company did you order your vinyl floor from?
1991 GMC Jimmy 4x4
Old 05-06-2012, 12:23 PM   #17
Keith Seymore
Capt Kaos.
K
1979-1986
1986 - 2019
Old 05-06-2012, 03:04 PM   #18
88Jimmy4x4
88Jimmy4x4's Avatar
dang I always forget about his store
thanks
1991 GMC Jimmy 4x4
