what color is this in ppg codes?
I'm sure some of you have seen this truck before. I am planning to paint mine red and white also and want to go with this red color. My painter told me he could match ppg paint easily. He uses a matrix painting system. Does anyone know what color this is? Any help is greatly appreciated.
1972 Custom Deluxe LT1 Gen V Swap "Green Lantern" 1984 Silverado Red Baron-72 c10 Project |
The Older Generation
Re: what color is this in ppg codes?
I can probably find the paint codes for the '71 in the link below if you think they are close enough. I sold it shortly after I finished it but I kept the codes because I want to paint another truck the same color. It turned out great. It was PPG base coat/clear coat. http://67-72chevytrucks.com/vboard/s...d.php?t=343754 My '39 Ford Coupe is painted with the Matrix System. It is Cherry Red. I have the number for it also... LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 02-28-2012 at 08:32 PM. |
Yep the truck looks great Leon. I looked through your post. Could you get me the ppg color code and name. It looks like it may be a little diff than the ford, but maybe it is just with the white throwing me off. Thanks so much.
#4 | |
LockDoc
Ever get this code for me? Paint is getting close? His truck in link. anyone have a similar color with a code? mI have paint coming soon and need to get matrix color code.
1972 Custom Deluxe LT1 Gen V Swap "Green Lantern" 1984 Silverado Red Baron-72 c10 Project Last edited by srea76; 05-02-2012 at 08:48 PM. |
I didn't have any luck finding the left over paint. I must have given it to the guy that bought the truck. I did find a can of spray paint the other day when I was looking for something else, that I had made up for touch up or painting small parts. The paint I used on the truck was PPG OMNI Base Coat - Clear Coat. The information on this spray can is as follows. Manufacturer: Queens Surface Bus Company Brand Code: 3794 Main Layer: 3794 ALT Oem Code: FLEET Description: Safety Red-Maintenance Mixing Scheme: OMNI AU (MAE) Price Code: D VOC Reg. 4.45 lbs/Gal Variant:ALT (LF) MSDS: MAE3 When you put the base coat on you will be shocked because it has a pink tint to it. As soon as you put the clear on it, it turns into the most beautiful Red you ever saw. The White is not a pure White, It is 1956 Chevrolet India Ivory. It really compliments this red paint. LockDoc
Man of Mini-Talents
PPG 4230, 2011 Corvette Torch Red
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
If I am remembering correctly, The Torch red is a car color and Victory red is a truck color, same color different names. Something to think about because all things with the Corvette name linked to it makes it more costly.
#9 | |
Man of Mini-Talents
You're right about the Corvette tax, but when it comes to paint, all reds and yellows cost more than other colors.
#10 | |
![]() Join Date: Apr 2005
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
![]() Join Date: Jan 2011
Is this the chart you're looking for?
Cheers, |
