Senior Moment
![]() Join Date: Mar 2002
Its Here , Its Here
My new Currie Enterprize F@rd 9" Posi rear end is here.
But they forgot to send the Trac Bar, So I cant install untill next week-end I'm so happy, Yet so bumded. ![]() ![]()
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
Looks $$$$$$
Got big-block?
![]() Join Date: Jul 2000
Sweet!
If / when I grenade my 3.73 posi 12 bolt in Daisycutter, that looks like what I'll need to get. SC
'68 CST SWB factory 396/T400 buddy buckets, a/c, ps, pb '72 Corvette convertible 454/4spd/ac, ps, pb '73 GMC Sierra Grande short wide 454/T400 ps, pb, ac '77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original '78 GMC Sierra Classic short wide 454/T400 ps, pb, ac '72 GMC Sprint SP454. 1 of 38 built. '73 GMC Sprint SP454. 1 of 71 built. '75 GMC Sprint SP454. 1 of 25 built. SOLD! '72 GMC K25 4x4 468/4L80e/NP205 build thread http://67-72chevytrucks.com/vboard/s...23#post4324423 SOLD!'55 Chevy gasser 496/4spd build thread http://67-72chevytrucks.com/vboard/s...96#post4324396 |
KEEP ON TRUCKING
sweet theyre just teasing you it will be there in a day or 2
72 cheyenne 2wd lwb 71 k20 sons bassett va |
damn thats sweeet
70 longbed 496/th400/Ford 9" |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Abuddie of mine had 2 currie axle's built for his early bronco and when the axle's arrived they were also missing some item's..(2 trusses and plateing on the bottom of the pumpkin were not there) Does currie screw up order's alot????
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Senior Moment
Man I hope not
That looks great! Just how much was that setup? Did they know exactly where to put the control arm pads?
1968 Chev SWB with 1998 Corvette LS1 305hp and 320 ftlb to the wheels (stock engine!) AEM EMS and wideband O2 sensors Bowtie Overdrive's 700R4, stage 3 Baer 4 wheel discs and 20s http://iciclelanding.com/aperture?album=2049&view=album |
Senior Moment
$2100 plus shipping $150 . I measured and gave them what I had and they said, " Thats want we have" . I'm sure I'm not the 1st 67-72 they have built one for. When it arrived I re-measured and it looks good to me. If they wouldn't have forgotten the Trac -Bar it would be in trhe truck and I would be a happy camper
I'm curious.... What is it about the ford rears that makes them superior to the GM units..???
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA 72 Stepside Project |
Senior Moment
To be perfectly honest Vinnie I don’t know for sure. I know the gears are beefier and are supposed to be stronger. I needed to have my rear end done and it was going to cost ~$1500 (yes I know some guys do it cheaper) so I figured for another ~$500 - $600 Why Not
Formerly yellow72custom
The Ford rears have a modular center section. If you decide you want to switch gear ratios, simply drop out the center section and put in a new one.
If you want to swap rears on a non-modular rear (such as a 12 bolt Chevy), you have to completley dismantle it, and install new gears to precision tolerances. Gears, parts and isntallation can easily run up to over $500, much more if you want a posi unit. The more expensive yards around here want $150 for a complete 9" center section with 3.50 gears and positraction......defenitly much easier and cheaper to deal with ![]()
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
