Old 05-03-2012, 07:23 PM   #1
Shane22696
Shane22696's Avatar
Power Steering
The PS pump on my truck is squealing like crazy. And not just the normal full-lock squeal. It makes the same noise, but it does it randomly at any point in the cycle. I can just barely turn it and it will shriek and bump back on the steering wheel. It's really embarrassing when I'm in the high school parking lot and all you can hear is belts squealing instead of my flowmasters. Please help guys, I've tried new belts and tightening them, that's not the problem.
80 K10 350 4 spd
4 Inch lift, 33 inch BFG M/t
Shane22696 is offline   Reply With Quote
Old 05-03-2012, 07:30 PM   #2
Stew_Magoo
Re: Power Steering
Maybe you should put some fluid in it.
Stew_Magoo is offline   Reply With Quote
Old 05-03-2012, 07:31 PM   #3
Shane22696
Shane22696's Avatar
Re: Power Steering
It's full. Thanks.
80 K10 350 4 spd
Old 05-03-2012, 07:42 PM   #4
tucsonjwt
Re: Power Steering
Is it leaking? If not, siphon some out and add some miracle steering fluid additive from the auto parts store. If it still squeaks, get a new pump - easy to replace - just leave the cap off after installing a new pump and turn the steering wheel from side to side until the pump level goes down and top it off to the full mark.
tucsonjwt is offline   Reply With Quote
Old 05-03-2012, 07:48 PM   #5
Shane22696
Shane22696's Avatar
Re: Power Steering
No it's not leaking. Do you have any suggestions for brands of additives?
80 K10 350 4 spd
Old 05-03-2012, 09:13 PM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Power Steering
make sure the pullies line up straight
headers or manifolds?
some people cut off /remove the steering brace at the first plug when putting in headers
helps to keep it tight
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 05-03-2012, 09:16 PM   #7
Shane22696
Shane22696's Avatar
Re: Power Steering
It's got headers, I just kind of left that bracket hanging. The pulleys appear to be lined up with the motor off, do you think it being unbolted there could be making it unstable?
80 K10 350 4 spd
Old 05-03-2012, 10:16 PM   #8
donut
donut's Avatar
Re: Power Steering
Yes, wore out that t-shirt long ago.
I usually use the stud that came out of that hole on the manifold and make a spacer to take up the slack (same thickness as the manifold.) if the stud is gone, you can use a longer bolt and the spacer.
Tension on the belt can be enough to throw that pulley off just enough. Lock it down and see if it still does it, go from there. Don't forget to loosen the belt first, makes life a lot easier.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 05-03-2012, 10:21 PM   #9
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Power Steering
yup I'd bet that would fix it
John
Old 05-03-2012, 10:44 PM   #10
Shane22696
Shane22696's Avatar
Re: Power Steering
Alright thanks a lot guys! I'll make a spacer tomorrow before work and see if that fixes it.
80 K10 350 4 spd
