Old 05-03-2012, 11:14 PM   #1
WIDESIDE72
WIDESIDE72's Avatar
700r4 shift linkage
Does anyone else know, or have input as to what shift linkage they used in swapping in an O.D.? There are several threads on here regarding swapping them in, but no details as to the linkage, so I assumed that the old TH 350/ 400 linkage would work on the 700R4 I am installing. (Not the case) I have all of the stock TH350 pieces (rod, frame brackets and intermediate piece that slips over stud n frame bracket). The selector shaft is different on the 700r4, so it looks like I will need to cut each of the two selector shaft brackets apart and make a hybrid. I am also looking at a lokar set up that eliminates the fulcrum and goes straight from the colum down to the trans. Has anyone had any experience with this piece?
WIDESIDE72 is offline   Reply With Quote
Old 05-03-2012, 11:28 PM   #2
HotRod C/10
HotRod C/10's Avatar
Re: 700r4 shift linkage
subscribing.............
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 05-03-2012, 11:58 PM   #3
gearys 5600
gearys 5600's Avatar
I used lokar.
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629
1969 custom/10 swb--SOLD
1968 swb 50th anniv.--SOLD
1967 camaro ss/rs..LS-6-speed, 16-year long project
1956 chevy nomad
1955 chevy 210 2-dr sedan
1978 el-camino ss 1-owner
gearys 5600 is offline   Reply With Quote
Old 05-04-2012, 12:14 AM   #4
jjzepplin
jjzepplin's Avatar
I have a 700r4 in my Truck and used stock linkage . I modified the shift section of the column and it hits all gears. Only the downshift is different and needs a bracket at the carb to fix it. But linkage is the same as my th350..sept makin the shifter go down farther to get to first gear..
jjzepplin is offline   Reply With Quote
Old 05-04-2012, 09:33 AM   #5
beach
beach's Avatar
I was able to use all the stock linkage with my swap, just had to swap the bracket from the th350 on to the 700r4, everything lined up fine.
70 chevy long bed
72 gmc short bed
69 427 corvette (next project)
beach is offline   Reply With Quote
