is my 1976 small or big hump for carpet replacement?
Need to order carpet, all the catalogs say floor shift manual trans and 4x4 are big hump and 2wd auto are small hump. However I have heard all bolt in humps are big....Im confused because I clearly have a bolt in hump and cutout for standard trans if needed.
1976 GMC Sierra C15 2wd TH350 trans with 350 VIN L engine Is there another way to tell? Heres a view looking from underneath my truck ![]()
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
Re: is my 1976 small or big hump for carpet replacement?
JB, it looks like your truck was originally a 4spd granny. I think thats a high hump.
John 82 Chevy Silverado 350ci/TH350 ![]() |
anything is possible, but theres no indication of a clutch pedal or any linkage anywhere
The hump looks totally factory but the patch that is rivited in doesnt.
John 82 Chevy Silverado 350ci/TH350 ![]() Last edited by J Knight; 05-02-2012 at 08:29 PM. |
still confused
My guess would be high hump because it's bolted in. It's only a guess though.
Look here, http://forum.73-87chevytrucks.com/sm...c,11838.0.html
'86 C-30 dually, 454/tbh400 '73 K-20 350/350/205 (sold ![]() I'm kinda like duct tape- no real purpose, but handy to have around. |
LMC shows two carpet options, a 2wd low hump, and a 2wd/4spd or 4wd high hump. My guess is also high hump.
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=121
looks like a high hump, can you get a pic from the inside?
#9 | ||
Im gonna remove carpet/seat this weekend and take an inside pic
Pics worked for me (even on dial-up) and they're in his tech section so they're pretty much locked down. You may have to wait for them to load though.
When you post up a pic of yours, someone will help identify exactly what you have.
This is a pic from a 76 3/4 2wd manual. I called this high hump. Not sure if this helps....
2wd auto/ 2wd manual column shifted = low hump
2wd manual floor shifted (both M20 and My6); and 4wd = high hump As others have said - looks like you've had some floor shifted manual action at some point in the past. What makes you think the truck was originally a TH350? Because that's what's in it now? Any other indications (brackets and such) that would indicate it was originally a manual trans? K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#13 | |
this the big hump right? does this look like yours Keith?.....whats this cover plate near brake on firewall? so this is large hump right?
Looks to me like a 2wd high hump, same as pic xrcr posted.
Hole in the floor, clutch? Kinda looks like it as the patch jobs look similar, or at least done at the same time.
#15 |
I agree, looks like a 2wd high hump.
I neglected to take any pictures of my bare floor; it's a 2wd high hump (because of the MY6) but not a bolt in. K
#16 | |
Thanks for the help everyone Keith.....what company did you order your vinyl floor from?
#17 |
Capt Kaos.
K
#18 |
dang I always forget about his store
thanks
