Old 05-06-2012, 08:35 PM   #1
Number21
Number21's Avatar
How to adjust throttle cable?
So I finally realized that my throttle cable is not hooked up right and pedal to the floor does not completely open the carb. How do I adjust the throttle cable? I think it needs to be tightened up a little. Do I do that from the carb end (I have an edelbrock if it matters) or on the pedal itself?
Inside the cab I can see there is about 1 inch of play in the pedal before it starts pulling the cable. Can I just shorten this?
'73 K20 Cheyenne Super Camper Special 350/TH350/NP205 sittin' on 33's.
You can set my truck on fire and roll it down a hill,
and I still wouldn't trade it for a Coupe de Ville.
Number21 is offline   Reply With Quote
Old 05-07-2012, 12:18 AM   #2
joe231
joe231's Avatar
Re: How to adjust throttle cable?
What throttle bracket do you have? Sounds like it might be too close to the carb. As far as I know there isn't any adjustment...
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 05-07-2012, 12:36 AM   #3
Number21
Number21's Avatar
I haven't got a clue. How do I tell? I'll post a pic later.
Is there supposed to be any play in the pedal before it starts pulling the cable? Or should it be tight? I can move the pedal back and fourth about an inch without it moving the throttle.
Old 05-07-2012, 01:02 AM   #4
joe231
joe231's Avatar
There shouldn't be that much play. If the throttle bracket were farther from the carb it would take up the play...
CHEVY ONLY
Old 05-07-2012, 02:57 AM   #5
Number21
Number21's Avatar
Here's a crappy cell phone pic, my other camera wouldn't work. I added a cable clamp to the end of the throttle cable to take out some of the play, and that made a HUGE difference. It's still not the right way to fix it though...I'll try and play with the throttle bracket tomarrow.
Old 05-07-2012, 10:46 AM   #6
joe231
joe231's Avatar
To me, that bracket looks to be too close to the carb.
CHEVY ONLY
