Old 05-02-2012, 03:29 AM   #1
GMC70c20
how close is to close
I am just about to order the parts to build my 2006 6.0. I already got the heads (stock ls3 heads) I am going to replace everything minus the crank pistons rods and block. I was going to check my piston to valve clearance when I put it together, what I need to know is how close is to close?
1970 c20 converted to c10 sleeper
1979 c20 the wood hauler
1991 honda civic daily driver
spray and pray baby
GMC70c20 is offline   Reply With Quote
Old 05-06-2012, 10:48 AM   #2
code4
Re: how close is to close
.080, a lot of variables though. You must be milling the heads & a huge cam to be worried. Check this thread out:
http://ls1tech.com/forums/generation...clearance.html
code4 is offline   Reply With Quote
Old 05-07-2012, 02:29 AM   #3
GMC70c20
I was just going to take enough off the heads (if any) to get the warp out and the came is only .563/.542 lift. I have no idea how much clearance will be there I was just curious how close I could get safely.
spray and pray baby
