Re: Bendix Stromberg WW Rebuild
Well the float was stuck down (open needle) which is why fuel was gushing out. Figured as much. The body was physically stuck in the bottom of the bowl. No idea why, poor design, previous re builder installed wrong float? Who knows. I also read that it should be set a 32nd of an inch lower (7/32) instead of the 3/16 the factory says. Reason being according to what I read, is that the old fuel (lead?) was more dense, so the float was more buoyant I suppose. Not sure if this is gospel. I did these things, it's just fine. No idea if you can set the idle screws by vacuum gauge, can't find info anywhere. So I did it by ear, screw it in till it sounds bad, and back a half turn.
All in all it was fun, learning experience I guess. Still can't wait to do the Holley upgrade. If I notice any real mpg increases, I'll post back. But it'll be a few weeks or more, I don't drive it all that often.
68 GMC C2500 - 305 V6 - 4spd
