Old 09-23-2003, 12:30 PM   #1
Bowtiefreak
Bowtiefreak's Avatar
Bed mounts needed
I need all four bed mounts for my Short Fleetside box. The mounts are the ones that are riveted to the frame that the bed mounts to.
1968 Chevy C10 Short Fleetside/Wood floor
ECE 4-6 Drop / 406 Small Block
1971 Chevelle 427 Big Block
Bowtiefreak is offline   Reply With Quote
Old 09-23-2003, 02:29 PM   #2
zyggy72
Can't kick the addiction!
If the bed mounts are the same as the short step side mounts, then I have a set of bed mounts that I can remove from a frame I have.
zyggy72 is offline   Reply With Quote
Old 09-23-2003, 03:21 PM   #3
tom hand
CCRider
tom hand's Avatar
What is a bed mount? My fleetside bed just bolts to the frame
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 09-23-2003, 03:46 PM   #4
zyggy72
The bed mounts we are talking about are the brackets that are riveted to the frame that the bed cross sills sit on (located before rear axle). The pair closest to the cab should mount flat on the flat section of frame and the 2nd pair should mount on an angle on rise in the frame before rear axle.
Old 09-23-2003, 03:49 PM   #5
Bowtiefreak
Zyggy72-
I will have to check on this. I am not sure. I think they are the same.
Old 09-23-2003, 05:04 PM   #6
TxGary
TxGary's Avatar
I have all the mounts you need already removed from frame. If interested just let me know.
71 C-10 SWB
1969 C-30 Custom Camper Motorhome Restoration in progress.
2020 Chevy 2500 Crew 4x4 LTZ Diesel
2024 Chevy Tahoe Z71 4X4
2015 Diamond C 22' HD car hauler
Bowie, Texas 76230
TxGary is offline   Reply With Quote
Old 09-23-2003, 05:37 PM   #7
TxGary
TxGary's Avatar
Here is a picture of the mounts that I have.
71 C-10 SWB
Bowie, Texas 76230
Old 09-23-2003, 08:07 PM   #8
Bowtiefreak
TxGary-
Let me know what you may want for themand if youcould ship.
Old 09-23-2003, 08:17 PM   #9
MOTHERTRUCKERS
TxGarys parts are correct for short fleet & step beds. We have pretty much any mount,crossmember,hanger,a arm,trailing arm,coils,leafs etc. for 2wd 1/2 and 3/4 short or long bed truck in stock on the shelf for future reference. No 4x4 at all.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 09-23-2003, 11:16 PM   #10
TxGary
TxGary's Avatar
Bowtiefreak, sent you a PM on parts.
71 C-10 SWB
Bowie, Texas 76230
