05-08-2012, 09:53 AM | #1 |
whats this bracket?
I've seen this b4 but I dont know what is for.There is also a hook bracket that is bolted to the floor right next to the grommet where the fuel line goes through the floor(hard too get a pic of it) could these be for the jack handle?
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
05-08-2012, 09:59 AM | #2 |
Re: whats this bracket?
Yes its for the jack. 67 68 only i believe.
Posted via Mobile Device |
05-08-2012, 10:08 AM | #3 |
do you mean the handle cause the jack is still in the cab corner
05-08-2012, 11:06 AM | #4 |
Active Member
It's for the jack. These trucks came with a small bottle jack. A long spring held it in place. The handle was in a sack and pinned along the rear column with a spring.
Of course after 40 plus years these jacks were either lost, damaged, discarded or replaced with better ones like the one I have now. Here's a pic of what it should look like without the jack. |
05-08-2012, 11:12 AM | #5 |
Active Member
After taking another look at yours, it's a little different and seems to be located in a different location than mine. It may be a snap type holder for the handle?? My cab truck is a 68.
05-08-2012, 11:19 AM | #6 |
I have the same one in my 68 and another bracket about 10 or 12 inches away, near the trans. hump.
1968 Chevy C/10 LWB V8 1983 K5 Blazer 1989 C1500 Stepside Reg. Cab V8 |
05-08-2012, 12:31 PM | #7 |
Proud owner of a 55.1 AD
See if this picture helps, not sure who deserves the credit. It helped me quite a bit trying to figure out how the jack handle is supposed to be stored on my '67. LocDoc also has some great pictures and a detailed Jack Location Decal.
Good Luck! Bob |
05-08-2012, 01:37 PM | #8 |
Active Member
In picture above the bottle neck jack is installed backwards. Originally the base fit in the recessed area and the neck under the spring. At least that's how it was installed on mine before I got rid of the old jack.
05-08-2012, 02:34 PM | #9 |
425hp409
68gmsee is correct about the jack. That picture is how my 68 is.
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
