05-10-2012, 07:27 PM | #1 |
Horn wont work
i just got an 85 chev c10 on friday. the horn wont work, i have bench tested the horn, works fine. which fuse is the horn run through, the only one that i dont have power to is the 5amp inst fuse. i have had the column apart to change the tumble every thing looks good there. the horn wire was cut just inside the engine compartment. i currently have a jumper wire running from the firewall to horn.
