Re: 68 aka "Chained in Porterbuilt Prison"
schott will make it happen, they are building mine. Brake caliper clearance was a concern because im using 14" sl6r and 13" sl4r wilwoods, they will pull the specs from whatever calipers/brakes your using and machine the wheel to work with your brake set up, they are all about perfection with there wheels. they are worth all the $ spent. Alot of people dont use them because they are very expensive but once you see them in person they are like a piece of jewlery. im in the wheel/tire field and they have the BEST polish ive ever seen i mean come on the polish it front to back...not many do that. plus the cover lock is awesome.
#2 | |
![]() Join Date: Apr 2007
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791 |
