09-23-2003, 09:00 PM | #1 |
a/c, non a/c cab difference
At some point before I bought my truck, a/c was added. It was originally a non-a/c. Holes were cut in the dash in the correct places for the vents. It's attached to the firewall with self-tapping screws. You can see where the original holes were. My question is this: What is the difference between a/c and non a/c firewall openings? I need to make sure everything works ok before the cold weather gets here. Thanks.
09-23-2003, 09:52 PM | #2 |
Rob'68
Here is a pic of a 68 factory a/c cab firewall
John Hutchison Grapevine,Texas 68 1/2 t swb 68 Mustang 69 Jaguar 71 1/2 t swb 88 Supra CompTs6m 93 Escort GT 2005 Corolla XRS |
09-23-2003, 09:53 PM | #3 |
and here is a 68 non a/c cab firewall.
09-23-2003, 10:02 PM | #4 |
Rob'68
There are a couple of other differences if you look at the first cab there is a hole in the firewall next to the chalk mark number 2on the left which allows a flap to be mounted inside the cowl area to open and close via a vacuum assisted module. There is also another device that is vacuum operated which is attached to the passenger side cowl vent on the kick panel. These have to do with the fresh air circulation. Other will supply more detail, as this is a common upgrade All in all if I were doing it I would look into aftermarket as they are much more efficient and the final cost is about the same Have fun
09-24-2003, 07:30 AM | #5 | |
Glowing since 1978
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in 71 Corvette Coupe 454 4 speed 69 Chevy C20 Custom Camper |
