Old 05-12-2012, 07:57 AM   #1
JimKshortstep4x4
Re: Radiator help / Fan shroud
My son does not have the big block truck anymore but it used clips on the bottom instead of the screws. The clips have a little more leeway.
Is the fan centered when the shroud is attached at the top?
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 05-12-2012, 12:34 PM   #2
mikewarme
Jim
I have the clips as well but if you attach it to the top than the shroud just misses the bottom to short clips wont reach. No Fan seems too low. But that still would not solve the shroud from attaching at top and bottom.
Aarrrrrrrrr
mikewarme is offline   Reply With Quote
Old 04-14-2013, 02:37 PM   #3
Bruser
I have the same problem with my sb350. did you ever figure out the source of the problem? How did you solve your issue? Been looking at threads but haven't found an answer yet
Bruser is offline   Reply With Quote
